[WTS] Used 1.8 Proton Putra/GTi Gearbox F5M222VRXE
KRZ8v
Beyond 20,000 RPM!
20,987
4
KL/Subang Jaya
Item: Proton 1.8 Putra/Satria GTi 4G93 Gearbox code F5M222VRXE to letting go cheap2.
Condition: Working but housing got a punctured crack. Been modified to pair with 9" flywheel and clutch set. Have to patch up the crack b4 it can be used again.
Solution:
1~Change front housing/enclosure (Recommended)
OR
2~Send it for aluminum welding at any welding shop (cheaper)
OR
3~Patch it up with 2Tons metal bonding a.k.a Gam 2Tan (cheapest)
Price: RM1200 negotiable. RM1000 last price. Call for easier dealing.
Pics:
Grind-ed section to fit in the 9" Flywheel and clutch set
Hairline crack (leaking transmission fluid)
Hole on the outside section. Does not effect anything.
Code F5M222VRXE
HICOM Casting
Dealing Method: COD only. Subang Jaya, S.Alam Sek26/27, Batu3, Sunway.
Contact: 013-3809612 Zaini
Xtreme Drift/ Drag Flywheels
  • Manufactured from billet Chromolybdenum
  • Available at or above the vehicle's standard flywheel mass
  • Ensures maximum torque throughout the RPM range
  • Designed to maintain engine's inertia while providing the security of an explosion-proof motorsport system
  • Most experienced drag racers and drifters recognize the need for a flywheel with increased mass
Visit
Syahz's FotoPage -...
