(WTS) spark control!!!!
decapullet
hi guys...
i got a new performance products which call SPARK CONTROL device...
it is functioned to provide a consistent spark plug ignitate longer than normal..
proven on dyno test...to increase bhp...very suitable for NA or Turbo cars...
one unit of SPARK CONTROL to be tapping for one coil unit...so if u have 4 pistons just add two unit then u r ready to feel the instant respons.........
retails official prices is RM150.00 per unit...now promotion just rm120.00 per unit new...with installation...
warranty one year...
please view attached picture..which attached to my EVO 3 engine...increase 20hp on dyno test...PROVEN...
INTERESTED PLS CALL ME AT 0193494440
SHAH DECAP
bro, your dyno sheet that proven the benifit of this spark control? can u show us, i am interesting la...
lets meet up and i will show u....bro...
i'll do demo also...
cheers
no bro...two piston = two plug cables....only have to connect one unit....so if u have 4 piston need two unit to install....
simple calculation...
4 pistons engine = 2 spark control unit...
6 pistons engine = 3 spark control unit...
cheers
cheers
oh.. ok ok.. now i understand... this spark control thing is to boost up the spark wan la... = ) :driver:
mind to explain more where to install and how that thing function...
ok shazmi...
ok this device is actually link to ur plug coil...it can control ur plug sparks timing process....in a normal spark plug system..the sparks timing is inconsistent and very few sparks per second....u can experiment it your self by remove ur plug cable and put it near any metal parts on ur engine..then u can see the sparks turn to be on off rapidly.....but after installing this devices..instantly u can see the sparks going to be consistent by notice on the longer sparks connection to the metal parts..
further lets meet up and i demo to u..
cheers
bumps...up..
good stuff....
proven on track as well as on the road..
cheers
bro fst...
if 4 piston turbo..mitsubishi engine like 4G63 T evo's, GSR got two coil then u have to use two device...but if local engine /proton SOHC which have only one coil so have to use one device only..
thanx...
cheers
bro fst...
thanx...
cheers
bro decap,
mine is 4g91, the coil u were saying is distributor coil u mean?? from what i saw there is only 1 ?
enlignten me more on this as i am looking for something that can give me more sparks, i dont want those gimmicks which claims can give me more sparks but end of the day there is no significant changes.
hope you understand bro.
rgds
This is interesting. Does this gadget run on it's on power supply or what? How does it work? 20bhp with one gadget is very very very significant
can this gadget be installed on a L2s ?? 3 piston how ?? any reviews on its capability by other users ??
how about cars like vios? no plug cable 1. still can use?
yes bro.1023.for vios...
each cable got coil under plug cover....so u need all 4 devices attached to each coil........thanx
yes bro fstrader..
the one attached to distributor coil...lorr.....single coil..then use one devices only..
thanx...
hi izso...
ok the product is shared power from 12V power supply available from the coil +ve life wires and the next process of this device is to prolong and give a sparks stability to perform reach consistency level...
SURE NO GIMMICK...DEFINITELY CAN FEEL THE RESPON INSTANTLY...
CHEERS
