[WTS] ROCKFORD FOSGATE Power 1001bd Monoblock Amplifier
ICE -In Car Entertainment
ACG-KAiZEN
If you're looking for a dedicated, bass-driving animal, say hello to the Big Dog — Rockford Fosgate's Power 1001bd! Equipped with Class bd technology (Rockford Fosgate's patented digital amp design), this beast produces an amazing 75% efficiency rating with a highly stable output. Even under heavy loads, it will maintain steady power flow and a cool temperature, saving your music from clipping and distortion.
Up for sale is an USED ROCKFORD FOSGATE Power 1001bd monoblock amplifier.
•Class bd technology
•500 watts RMS x 1 at 4 Ohms, 1000 watts RMS x 1 at 2 ohms
•requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
•100-amp fuse and fuse holder required
•selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
•MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
•TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
•NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance.
•preamp outputs for easy connection to a second amplifier
•wired remote control of Punch Bass (0-18 dB centered at 45 Hz) — gives you fingertip control of your bass impact
•subsonic filter removes frequencies below the range of human hearing for increased efficiency
•dimensions: 14-7/16"W
Item(s): ROCKFORD FOSGATE Power 1001bd monoblock amplifier
Price: SOLD!!! SOLD!!! SOLD!!!
Dealing method: Prefer COD (KL, Damansara, Kelana Jaya, Subang Jaya, Sunway, Bandar Utama & PJ Area)
Contact method/details: 012-21 363 07 / 016-351 3337
Item(s) conditions: ITEM IS IN PERFECT AND MINT.
Picture: AS PER ATTACHED
SPONSORED LINK
wow,old skool beast,best price?
