[WTS] PIVOT MULTI GAUGE XV (Only suitable for :VW and Audi)
jpoplover
7,000 RPM
Nilai
http://pivotjp.com/product/eurospec/img/xv_a_main-e.jpg
http://pivotjp.com/product/eurospec/img/xv_detail-e.jpg
http://pivotjp.com/product/eurospec/img/xv_illumi.jpg
http://pivotjp.com/product/eurospec/img/xv_coupler.jpg
http://pivotjp.com/product/eurospec/img/xv_install.gif
Indigo Bule Illumination (XV)
Standard indigo lamp provides an eye-pleasing sleekness. (VW GOLF, PASSAT, etc.)
3 in 1 Display
With just one unit switch between three displays: Boost, Oil and Water Temperature.
No need for hassling with pipes and wires
Coupler connection to the diagnostic monitoring connector for easy-installation.
*It is necessary to connect the power source to the Fuse Box.
Peak Hold Function
Save and display peak reading.
•This product connects to the diagnostic monitoring connector and can not be used in conjunction with other products. (Except for 3-DRIVE)
•The display will not work properly and hence is incompatible if either of the following is the case:
1. The ECU is different from the standard for that model.
2. If a sub-computer is being used.
•Due to the ECU information received, the displayed values on this product may differ from those of standard or other meters.
Price: Rm950
Item condition: New, got stock
SMS/CALL 0166383725 For get best price
name: Y.H.LIM, jpoplover, joshua lim
Seller location: Negeri Sembilan
email: [email protected]
Dealing : 1. POSLAJU, kangaroo
2. COD: MID VALLEY KTM station,
3. COD: Seremban
