PIVOT DIGITAL MONITOR, DMC, DMC-G
DMC, Display color: Red
http://pivotjp.com/product/dmc/img/img_dmc_s.jpg
DMC-G, Display color: Green
http://pivotjp.com/product/dmc/img/img_dmc-g.jpg
http://pivotjp.com/product/dmc/img/size_dmc.gif
Basic Wiring:
http://pivotjp.com/product/dmc/img/wire_dmc-e.gif
· Unit Size
51 × 35 × 20 (Depth) mm
Multi data display:
Switch between Water Temperature,RPM and Voltage in the same unit.
Easy installation:
Simply connect to the diagnostic monitor connector.
Thin compact monitor:
14mm Flat-Design allows for Unobtrusive Installation.
Peak hold:
Save and display peak reading.
Compatible car model:
For CAN Data Communication Model Cars.
Before purchasing make sure to check the “Fitting List”.
Please read the following before purchasing.
• 1 See here for more about using in conjunction with other OBD2 connected products.
• 2 The display will not work properly and hence is incompatible if either of the following is the case:
1. The ECU is different from the standard for that model.
2. If a sub-computer is being used.
• 3 Due to the ECU information received, the displayed values on this product may differ from those of standard or other meters.
http://pivotjp.com/product/x2c/img/X2C_X2R_DMC-list.pdf
Price: RM6xx
Item condition: New, got stock
SMS/CALL 0166383725 For more info
name: Y.H.LIM, jpoplover, joshua lim
Seller location: Negeri Sembilan
email: limkinboa@hotmail.com
Dealing : 1. SKYNET, poslaju
2. COD: MOST KTM station in between midvalley to seremban
3. COD: Seremban/nilai/Sepang
http://i51.photobucket.com/albums/f392/mls_gamer/DSC_4426.jpg
Basic Wiring:
· Unit Size
Multi data display:
Easy installation:
Peak hold:
Price: RM6xx
