Wts:Pivot ACS AirFlow controller
4_throttle
Puchong
got 1 unit of used pivot acs for sale,
pic attached,
Price is rm300, (offer)
come complete with wiring and wiring connection diagram..
selling cos upgrade ECU..
Interested please call 012-3396628, no sms please.
Thank.
Tech spec bumpppp
Spec description from pivotusa.com website
Air Flow Controller SystemPIVACS-Rhttp://www.pivotusa.com/images/seperator.gifhttp://www.pivotusa.com/aftuning/images/spacer.gif
•High Performance CPU Allows Engine Combustion Adjustments at Various Engine Speeds
•Illuminated Knobs Change Color to Indicate Changing Point
•Features the same Proven Japanese Electronic Quality Found in All Pivot Products
•Easy Adjustments While Wearing Racing Gloves
•Compact Size
•Easy InstallationWhen you add aftermarket products to your car (intake, exhaust, cams, forced induction, nitrous, etc.) the fuel supply provided by your stock computer isn't enough to make full use of the parts you put on, causing a lean condition (not enough fuel). This can lead to detonation, and in extreme cases, engine failure. The Pivot ACS-R Air Flow Controller overides the factory settings and allows you to bring your engine into it's optimal, safe, operating range. In the extreme opposite, the engine may run too rich. This can foul out spark plugs, destroy catalytic converters, and causes the engine to bog down. The Pivot ACS-R Air Flow Controller allows you to lean out the air/fuel ratio to get the most of your aftermarket performance products.
http://www.pivotusa.com/aftuning/images/acs-r_animation.gif
come with manual and full wiring ?
bro 300???interested....do u provide installation?????
