These FX-R Bi-xenon projectors were designed specifically with retrofit in mind.
Come with bare-ended pigtails connect to hi-low solenoid input wires to plug into your high beam wiring, making it fully plug-n-play. Come with 4 corner mounting holes added to cast body.
These projectors comes with pre-optimized clear lenses to give them an intensely lit beam pattern with a sharply defined and colorful-flicker cutoff line.
Let the beam performance comparison speak for themselves. Their output surpasses the OEM FX bi-xenon in terms of intensity, light spread and cutoff sharpness. The beam performance on the FX-R projectors among the best, watch it yourself in youtube. Just search for FX-R projector or HiDplanet : The Official Automotive Lighting Forum - The Buzz
Selling for RM550 include:
Can my existing Projector Headlight retrofit to FX-R projector? :hmmmm:
Can my existing Reflector Headlight retrofit with FX-R projector? :hmmmm:
YES! as long as you have New or Existing:
HID Bulbs: 35Watt Generic D2S or Philips D2S (85122 or 85122+) for best performance
Ballasts: OEM or Aftermarket type ballast able to fire-up 35W D2S HID bulbs
Headlight type: Clear/ Smoke plastic 'polycarbonate' or Glass lenses.
*Not recommended for fresnel and prism lens molded type headlamp that would results in excessive glaring.
Please feel free to mail/PM/call should you have any question.
Dealing method: COD or postage available
- 2x Brand new FX-R bi-xenon projectors with clear lenses (Low/High Beams)
- 2x Shroud/Bezel
