item no 1
10 gb IBM Travelstar 2.5 for Notebook
capasity - 10.05 gb ata/ide
speed - 4200 rpm
model - IC25N010ATDA04-0
Made in Thailand
http://i1.lelong.com.my/UserImages/Items/0511/25/[email protected]
Note :
Format new with little big Bad sector
still can install OS dan detect by bios and working.
Rm 55 Firm - SOLD
item no 2
NEW DELL DVI to DVI VIDEO CABLE
DELL DVI Digital Monitor Cable for Flat panel monitors or any monitor that has a Digital Input.
http://images.astepnet.com/www.astepnet.com/DVIXXX-XXMMb.jpg
Digital Visual Interface (DVI) is the standard interface for a high-performance connection between PCs and flat panel displays, digital CRT displays, projectors, and HDTV. DVI Dual-Link Digital/Analog Video Cables deliver the high-performance, high-bandwidth interface needed for video displays of today while leaving headroom for the products of tomorrow. These precision-engineered cables are fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVD-D dual link configuration provides enough bandwidth for resolutions up to 2048 x 1536 and allows high speed digital transmission up to 9.9 Gbps.
* Connectors: DVI-I 29-pin Male to DVI-I 29-pin Male
* Dual link digital signaling allows for high speed transmission up to 9.9Gbps
* Three analog 30awg coaxial lines allow for high speed analog transmission
* Each coax line is individually wrapped in foam-polyolefin insulation and overwrapped with a braided tinned copper shield
* 28AWG copper conductors are individually insulated in hard-density polypropylene to minimize cross talk, ensuring high-speed, error-free transmission
* Ferrites on each end to block out unwanted signal interference
* Shielded under mold protects against unwanted EMI/RFI interference
* Gold-plated contacts provide full conductivity with no data loss
* Supports hot plugging of DVI display devices
* PC and Mac compatible
* Resolutions up to 2048 x 1536
* Supports digital and analog signals
* Compatible with flat panel displays, digital CRT displays, projectors, and HDTV
* Meets DVI DDWG Standard
Cable is 6FT. Long
Sale Rm 20.00 - SOLD
item no 3
USB 2.0 A to B Cable 6ft Long BLACK - NEW
http://www.pccables.com/images/70507.jpg
USB universal serial bus cables provide transfer rates up to 480Mbps for easy attachment of any USB device
# Connector: USB Type A Male to Type B Male
# Transfer rates up to 480Mbps depending on USB version
# Designed for devices as keyboards, mice, modems, printers, and other USB perpherials and Switches
# Connect a USB perpherial to an USB Hub or USB port on PC/Mac
# Downward compatible with USB specifications 1.0, 1.1, and 2.0
Rm 15.00
Item no 4
NEW CISCO CAB-ETH-S-RJ45
http://i11.ebayimg.com/02/i/04/79/1d/54_1_b.JPG
NEW CAB-ETH-S-RJ45.
72-1482-01
New Yellow Cisco CAT5 patch cables, still in the original packaging. The Cisco item # is CAB-ETH-S-RJ45 from Cisco Aeronet Wireless Access Point box. This is a standard straight through cable.
This LAN cable can be used to connect from your switch to other networked devices (laptop, routers, networked printers...)
Rm 15.00 each
quantity = 2 pcs left
item no 5
Sun VGA 13W3 to VGA Adaper Cable
http://i9.ebayimg.com/04/i/05/70/dc/e7_1.JPG
P/N 530-2917-01
Working Pull. Excellent Condition. Previously in use with SUN GDM-5410 Monitor
rm 15.00
item no 6
Cisco 72-1213-01 PIX Firewall Failover Cable
http://www.andovercg.com/ebay/images/san-0302.jpg
rm 15.00
item no 7
Sharp Surround speaker
1. central speaker
2. right speaker
3. left speaker
rm 55.00
item no 8
6 Feet USB A Male to Mini B2.0 Cable
http://images.astepnet.com/www.astepnet.com/usb2-6minb.jpg
These fully rated universal serial bus cables provide transfer rates up to 480Mbps, depending on USB version, and easily attach to any mini-USB device. Mini USB cables are designed to connect from your USB port on Hub, PC or Mac to your USB device, including cellular phones and PDAs. Foil and braid shielding reduces EMI/RFI interference, and twisted-pair construction helps reduce cross talk thus ensuring high-speed, error-free data transfer. Meets all the UL requirements for communication cabling, and is compatible with USB 1.0, 1.1, and 2.0.
* Connector: USB Type A Male to Type Mini B 5-pin Male (MD Type)
* Transfer rates up to 480Mbps depending on USB version
* Make plug and play connections with cellular phones, MP3 players, digital cameras and PDAs
* Connect a peripheral with a 5-pin mini usb port to an USB Hub or USB port on PC/Mac
* Compatible with USB specifications 1.0, 1.1, and 2.0
rm 15.00
item no 9
http://a.im.craigslist.org/6L/nK/3rPgstNVkfofFOJUNUzoFvB0DctT.jpg
Halogen Floor lamp w/ CD rack and dimmer measures 72" H and holds approx 60 CDs.
rm 80.00
item no 10
http://i23.ebayimg.com/04/i/05/20/dd/49_1_b.JPG
IBM DCAS-32160 (2.1GB)
3 1/2" 5400 RPM Single Ended Fast/Wide SCSI
SCSI Drive
Model # DCAS-32160 E182115 S
MLC: E60259
2.16 Gig
RPM 5400
68 pin connector
Free scsi 68 pin cable 1 to 9 point with terminator
+ compaq 200mb hdd ide - no bad sector and working
item no 14
http://www.pricenews.ru/techinfo/EPS300.JPG
sample model for this printer - borrow from other website
unknown epson stylus color 300 - printer only with dry ink printer head
quantitty 2 unit
rm 20.00
item no 15
original wira cassete folder..
wanna picture pm me..i attach
rm 18.00 only
item no 16
17-04009-02 Digital SCSI 68-pin to 50-pin adapter Connector
Manufacturer Digital
PN 17-04009-02
Condition used
rm 50
item no 11
http://i1.lelong.com.my/UserImages/Items/0509/21/[email protected]
MADGE SMART 16/4 PCI RingNode TOKEN RING 2
Madge Smart 16/4 PCI RingNode 2 7N51-02 as pictured below.
This Card is Used full tested working.
This is a list of part numbers and alternates;
7N51-02
Once again, please check your system for compatibility to be sure.
rm 15.00
item no 12
3COM ETHERNET 10 megabits ISA Internal Card
Part Number: 3C905B-TPO
Chip set reads: Parallel Technology
3Com 40-0130-004
Condition: Used Pull/Tested
Automatic installation under Win98, WinMe, Win2000, and Win XP. Just install and operating system will automatically find and install softwares. May need Win98/Me CD to install.
rm 15.00
item no 13
17 pcs unknown capacity n condition edo ram
unknown cpu intel pentium w mmx tech without heat sink
unknown cpu fb521983ag malay iPP with heat sink
unknown digital memory 54-24329-da
hp 256 kb spb cache
unknown 50-23531-01 a01 l1 side - digital server
all for rm 50.00
speed - 4200 rpm
Made in Thailand
Note :
Rm 55 Firm - SOLD
item no 2
Cable is 6FT. Long
item no 3
Rm 15.00
Item no 4
NEW CAB-ETH-S-RJ45.
72-1482-01
Rm 15.00 each
item no 5
P/N 530-2917-01
rm 15.00
item no 6
rm 15.00
item no 7
1. central speaker
2. right speaker
3. left speaker
rm 55.00
item no 8
rm 15.00
item no 9
rm 80.00
item no 10
SCSI Drive
MLC: E60259
2.16 Gig
RPM 5400
68 pin connector
item no 14
quantitty 2 unit
rm 20.00
item no 15
rm 18.00 only
item no 16
PN 17-04009-02
Condition used
rm 50
item no 11
7N51-02
rm 15.00
item no 12
3Com 40-0130-004
rm 15.00
item no 13
hp 256 kb spb cache
all for rm 50.00
