[wts] Branded Car Audio Package – Morel, Orion, JL
Mid-year sales MATCHED SYSTEM – speaker, subwoofer and amplifier
PACKAGE PRICE – only RM1850 cash and carry*
Installation, extra charge. We offer premium cabling at affordable prices.
CALL 012-3315669 michael - NOW while stocks last.
Audio Creations brings you premium car hifi made affordable (end are the days of chap ayam). What you get is premium well-established brands, from
Morel – reknown home hifi and car audio speaker manufacturer,
Orion – legendary car audio manufacturer with many hall-of-fame amplifiers,
JL Audio – specializes in building high-end subwoofers for both home and car audio
Listening impression:
Black Eye Peas (The END) “meet me halfway” – separation of instruments and speed makes my feet tap to the music. the Orion power sure gives plenty of dynamics to juice the Morel speaker drivers, making it very enjoyable to listen, as bass is full and snappy. JL subwoofer seriously rocks with authority.
Stacey Kent (The boy next door) “the best is yet to come” - did not expect a system this price to be able to play this well but to our surprise, it handled it well and poised. not boomy or bright, just nice, good pace and very good air and space.
Diana Krall (Quiet Nights) “the boy from ipanema” – it goes ahhhh… the percussion, bass, drums is well reproduced without fatigue by the Morels. JL subwoofer does a wonderful job as it takes over the lower octaves cleanly without sounding lazy or boomy.
Amplifier: Orion HP-4800 4 channel
Loudspeakers: Morel Maximo 2-way 6.5” component
Subwoofer: JL 12WX-4 12”
- RMS @ 4 Ohm: 4 x 65
- RMS @ 2 Ohm: 4 x 100
- RMS @ 4 Ohm: 2 x 200
- Variable low-pass 50Hz to 500Hz
- variable high-pass with INTELLi Q 50Hz to 500Hz(rear channels)
- 10dB of boost with INTELLi Q
- Remote gain capable
- Selectable AUX out
- Fuse size: (2) 30 ATC
- Dimentions: 12.6" x 10.2" x 2.4"
- Power Rating: 65 Watts RMS x 4 at 4 ohms
- Signal to Noise Ratio: -80dBA (reference 1 watt into 4 ohms)
- Massive loosely-regulated MOSFET power supply
- All new pure MOSFET output stage design
- Intelli-Bass Equalization Circuit and Remote Gain Option
- Heavy Gauge Direct-wire High Current Power and Speaker Terminals
- 12dB/octave High- and Low-pass Filter
- Nominal Impedance: 4 Ohm
- Power Handling RMS @ 4 Ohm: 90W
- Max. Transient Power Handling: 180W
- Sensitivity (2.83V/1M): 90.5dB
- Frequency Response: 50-20,000Hz
- Crossover Point: 3800Hz 6dB/octave
- Voice Coil Wire: Copper
- Magnet System: High Grade Ferrite Magnet woofer and Neodymium tweeter
- Mounting Depth: 63mm (2.5”)
- Free Air Resonance (Fs): 27.43Hz
- Efficiency (1W/1m): 87.17 dB SPL
- DC Resistance (Re): 3.51 ohm
- Nominal Impedance (Znom): 4 ohm
- Thermal Power Handling (Pt): 200W
- Driver Displacement: 0.048cu.ft/1.36litres
- Net Weight: 5.8lbs/2.63kg
