[wts] AE111 BZR 6speed ECU
ngjenwei
Hi there, I got one piece 6speed ecu from Toyota Levin BZR. It also can be used in 5 speed BT. Best for spare for 6 speed BT or 5 speed can gain better respond in acceleration. The ECU # 89661-1A860 is for the C-160 6 speed equipped AE111 which are compatible with 5 speeds as well, but mated with 6 speed transmission outputs, it has premature rev cut points in 1st and 6th gear and slightly changed timing curves for a split second after lift throttle and re-application to ease and protect the 6 speed's synchronizer and reduce driveline lash. Speed cut at 8200RPM. Selling RM880nego. Interested please contact Kevin 0169688921. Location Kajang. Item still in my car. Perfect working condition.
Pic copied from other sources
http://memimage.cardomain.com/ride_images/1/3217/1261/8040630206_medium.jpg
good item free bump....:smokin:
Bump: good item free bump....:smokin:
Bumps for today!! Price is highly negotiable.....
my was swap from auto to 6 sp gbox..should i swap ecu also with this type..
Hi Ng, Can i check with you if ecu for haftcut with 6speed, wagon/carib/levin, are they using the same ECU like what u selling?
or BZR one is better one?
Hi, i thought that was the same but someone told me that it was different regarding the fuel mapping. Not sure for it. As i know 6speed ecu is better power than 5speed ecu.
up for today.........gain some power for your BT here
