[WTS] Accutire MS-5510B Racing Tire Gauge
kacw
Hi,
Comes with canvas bag for storage.
COD KL/PJ
Please SMS 0126704775
Cheers!
Accutire MS 5510B Features
The most Accurate Racing Tire Pressure Gauge available
Reads tire pressures from 0-60PSI in 01 increments
The quick disconnect insures a positive attachment
Easy to read blue back-lit display
Bleed valve to drop tire pressure to desired pressure
Accutire MS 5510B Description
MS5510B is the ultimate Racing Tire Pressure Gauge for the performance enthusiast. If you like to have the best tool available, this is the gauge for you. The MS 5510B is the most accurate tire gauge available. It reads tire pressure from 0 to 60PSI in .01 increments, with a large, back-lit LCD screen to make it easy to read. The convenient bleed valve makes it easy to drop the pressure if you overinflate. If you have a motorcycle, an off-road vehicle, ATV or performance car, get the most out of your expensive tires with accurate, consistent inflation.
Accutire Racing Gauge for peak precision. SAVE BIG! How many pounds of pressure? Here is the most accurate Air Gauge around for any tire with low pressure performance. 0-60 psi readouts in 1-lb. units; Extra large, easy-to-see blue backlit LCD; Bleed valve for precise accuracy; Quick disconnect; Shockproof rubberized housing; Installed lithium batteries (included); Screen: 1 1/2″, Tube: 12 1/2″, weighs 13 ozs.; Zipper storage pouch included; 5-year limited mfr. warranty. Act Now! Accutire Racing Tire Pressure Gauge.
