Hi Mates,
Thinking of letting go of my beloved 16V as i'm upgrading. Below are all NEW PARTS (unless indicated) that have been changed in my almost three year of ownership :
1. Front ori 16V absorbers
2. Ori suspension mountings and bearings
3. Ori lower arm bushes
4. Ori ball joints
5. Ori tie rods
6. Ori tie rod ends
7. Rear ori Gti-6 rear absorbers
8. Ori left and right driveshafts
9. Valeo Starter Motor
10. 90A Valeo Alternator (used)
11. Sanden Air Con Compressor.
12. Ori Fan Motor and Propeller
13. Ori Timing Belt and Bearings (only has done 15k since last change)
14. Ori Water Pump
15. Ori Oxygen Sensor
16. Ori Engine Fuel Hose
17. 4pcs Ori Ignition Coils
18. 1pc ori ACAV diaphragm
19. Ori Valeo Radiator
20. Ori Lower Cooling Hoses (from radiator to water pump)
21. Bosch Asbestos Free Front Brake Pads (imported from UK)
22. Bendix Rear Brake Pads
23. Ori Top Engine Mount
24. Ori Lower Engine Mount
25. Ori Gearbox Mount
26. Ori Body Kit and Side Skirt Clips (bodykit was fully removed and replaced with original items when the car was repainted)
27. Ori Accelerator Cable
28. Crankshaft Pulley
29. Ori Serpentine Belt
Aftermarket Parts
1. Sparco Front Strut Bar
2. Pro RS Braided Brake Hoses
3. Full SAMCO blue hose kit (same for 306 S16)
4. Full SAMCO blue vacuum hoses
5. Kingdragon Drop In Filter (cleaning kit will be included)
6. MAK 16 inch wheels shod with Goodyear Eagle F1 GSD2 205/45/16
7. ATE Grooved Power Discs for the Front Wheels
8. Australian Stage 1 Inlet Cam (same lift as standard but has more duration, 226 deg. @ 0.050” lift.)
9. 5 degrees offset key (installed together with the cam as it retains the standard intake cam pulley. So, timing can be set just like the original setup with the dowel pins)
10. Speedchip ECU (revlimit extended to 7500rpm)
11. Ori Devil France back box
There are many more items that i can't remember and all receipts are available upon request. Asking price is 25K and serious buyers only. Call me at 012-6122090 to view the car.
4. Ori ball joints
5. Ori tie rods
6. Ori tie rod ends
14. Ori Water Pump
Aftermarket Parts
