WTB : Silvia Spec R 6 speed Manual with Aero Kit
silviatub
30
Hi Mates,
Im a newbie and would like to know the current going price for a Silvia Spec R 6 speed Manual with Aero Kit. My budget is < RM110k and would prefer an unregistered and stock standard version. Please refer to the attached photo as this is the type of bodykit im looking for. :deal: :biggrin:
I had a SR20 DET engine in my first car and would love to revert back because of its robustness and reliability.
Also, kindly share what are the common problems associated with this car so that i can shop accordingly.
Thanks.
:driver:
silviatub
30
Hi Mates,
Any feedback? Any form of help is highly appreciated.
:driver:
slide_it
238
10
so far ive nvr seen an aero s15 here. all mostly vertex or dmax or uras. worse comes to worse get a frp copy one. beggars cant be choosers.
s15's are goin down in price. 2nd hand car market not doing very well. either u wait or if u lucky grab one when u see a good deal.
s15 common problem...the famous vct rattle.
Maz87
215
hmm.....Budget for RM110k, i think see before tat is at klang if not mistaken with Purple colour and stock standard all. This i saw in Motor-trader last months...
Actually i just get my silvia S15 in RM123k 2001year. So well friendly buy for this car...and very happy to get this negotiate prices from 130k til 123k.. As for sure Silvia already not coming in malaysia with recond car ,cause of 5 years AP already reach. So nowsday those Use car there have siliva also prices open in RM130k above... some i see before RM140 to 150k over...best price is RM145k also got....
Cheers
silviatub
30
Hi slide it,
The VCT rattle that you described is it from the inlet cam VCT actuator? Can this problem be resolved? Does it do any damage to the valvetrain?
silviatub
30
Hi slide it,
I have seen an aero kitted version in kl city centre last year...i just love the front bumper...does it belong to anyone here?
:hmmmm:
slide_it
238
10
silviatub: yeah on the intake side. the rattle happens usually on cold starts due to the cam gears not being lubricated enough. there are temporary solutions and permanent ones.
i dont think it would do much damage to the engine itself. just gets really annoying.
vct should happen during idle. it shouldnt happen while in gear and moving abt becos the gears are being lubricated. after starting the car, if u rev it in neutral and theres no rattle, then its prolly lifters not the vct gears. if u engage into gear and give it a lil rev past 2000 rpm and the noise goes away, but rattle returns once u idle, then its vct.
other possible causes that would make the rattle is sprockets, timing chain tensioner, timing chain guide, hydraulic lifters, solenoid valve
temporary solution, use thicker oil or revving it a bit during idle. permanent fix to vct problem is to upgrade the cam gears, cams. (u would lose the vct). to avoid it, change ur oil regularly.
btw i dont know whos car is that but i think in future u should blackout the plates :) cheers
silviatub
30
Hi slide_it,
Thanks for the info...its very helpful indeed...
Besides the VCT problems, any other gremlins to look for? How about the interior, suspension and drivetrain? Any particular electrical/sensor related problems?
I was told the JDM spec comes a garrett T28 ball bearing turbo...is this correct?
p/s : will blank off the number plate next time.
silviatub
30
Hi Mivec-Turbo,
Any other feedback regarding common problems with Spec R?
slide_it
238
10
mivec-turbo: honestly im still confused whether its VCT or VTC.
VCT = variable cam timing.
VTC = valve timing control. (as per s14 handbook)
silviatub: well since u in kl and msia is a freakin furnace, u might wanna check the whole airconditioning system is working. cos if the compressor is fkd, it would cost a lot. also check the digital climate control is working and cool air is coming out of the vents. stock water temp gauges are not very accurate. if u are afraid of overheating issues, get an aftermarket gauge. additionally a better radiator.
someone did post the same question but its not s15. irregardless, they are still both turbo cars and not the newest cars around. so symptoms shud more or less be the same. things to check
The Marketplace Top Posts
Hi I have a Lancer with a swap to a 4G92 MIVEC as per the picture:
Recently the oil pressure has started to go low when the engine is at idle/tickover.
This is shown on my oil pressure gauge as well as the oil light on the dashboard had been flickering.
Also the car won't go into MIVEC mode.
I have checked the oil, it is at the correct level on the dip stick and was only changed about 3000 KM ago, running 10W40 fully synthetic...
