Yeah bro, i know that..i was asking so cause 'ken yeang' mentioned that Monroe absorbers are not exactly a performance absorber and are just as a replacement. Since he mentioned that, i just wanted to know his point of view on getting a performance kind of absorbers. But i feel that my budget isnt enough on getting the coilovers, and better use the replacement abs with some thicker ARB's. Btw, thank you very much.Performance ones are those coil overs type.......
How much roughly would a performance coilovers which is high/low/soft/hard would cost? n maybe the absorber model?cause i might survey about it..guess the entry level of h/l/s/h coilovers would do..n i will try to save more money..n im starting to get confused again now.. :Let's put it this way : Monroe's aren't performance absorbers. But they are slightly better than the local Kayaba originals and last longer. So comfort isn't overly affected.
Performance absorbers would already be out of your budget, such as Koni, Bilstein, Eibach, etc. Forget about APM Performax, too short stroke and paired with the APM Performax springs it'll be way too low. Until every speedbump will make you slow down like a tortoise mating with a snail.
Performance coilovers best to save up for high/low/soft/hard. Just High/low is a big compromise since you're a cornering kaki. Also h/L has too little adjustments and you'll end up depending heavily on the tyres and adapting to the suspension (instead of the suspension complementing your skill).
Besides, for Wiras that old, too stiff will make everything rattle inside the cabin really badly. It'll take forever to find all the sources of the rattles and squeaks.
Sure bro..worth to save more money and getting something which is satisfying...TS, do ask around for more opinion. Take your time, while at it, save enuf money. Then splurge ALL your hard-earn money to a set of absorber/spring that really satisfying. Not cheapo/low quality setup that often regretful.
The prob is none of my friend or family members use different type of suspension..They just stay with the stock abs that arrived with the car..i never seen them changing it before..There is a possibility you saved up all hard earned money, gotten what you want and install once go for a run. It feel sucks, within months dismantle for sell and start hunting for a different set.
For i always do not recommend through brand based, seek what is the type of suspension feedback you want from riding through others car. Thus decide based on that criteria.
Normal every day drive sure use back Original specs loh, only those modding their car, go touge, take fast corner only will upgrade.....The prob is none of my friend or family members use different type of suspension..They just stay with the stock abs that arrived with the car..i never seen them changing it before..
That my friend is what i call social skill, it can't be taught over night. Seemingly you need to switch channel in for knowing new friends.The prob is none of my friend or family members use different type of suspension..They just stay with the stock abs that arrived with the car..i never seen them changing it before..
Wah! you getting stalked.....hope are girls......lolThat my friend is what i call social skill, it can't be taught over night. Seemingly you need to switch channel in for knowing new friends.
Recalled when i was just a fresh graduate, with my first car, all my friends are back in Sabah. Nowadays i even get stalked by going around.
From Mid to UHP tyres, sure stick loh .....hhahahhahaDon't forget to get good performance tyres as well. I changed suspension to RS One Mine's hilo body shift with my 1 year old falken ze912 size 195/50r15. The ride was quite bumpy and sometimes can feel the car like flying a bit at high speed. Upgraded the tyres to bridgestone potenza re003 195/55r15 and now the car sticks like glue and response very very well. When driving over those speed bump (breaker?) no more bumpiness.
Guess so....Normal every day drive sure use back Original specs loh, only those modding their car, go touge, take fast corner only will upgrade.....
Sure...Don't forget to get good performance tyres as well. I changed suspension to RS One Mine's hilo body shift with my 1 year old falken ze912 size 195/50r15. The ride was quite bumpy and sometimes can feel the car like flying a bit at high speed. Upgraded the tyres to bridgestone potenza re003 195/55r15 and now the car sticks like glue and response very very well. When driving over those speed bump (breaker?) no more bumpiness.
