Where to service 1jz-gte turbocharger
Anyone one knows where to get 1jz-gte standard Ct12a turbocharger serviced? currently my turbo unit is leakage oil through the turbo seal...so producing white smoke during idling.....and no smoke during on the move.....valve seal was recent changed.....and I have found oil traces in the air intake hose to the intercooler...
Please kindly help by providing contact details of workshop.(around KL or Klang Valley). Thanks.
I had the same problem , i suggest turbo tong in cheras . He replaced the ceramic fins with steel wheels to withstand more boost but its a bit more laggy now
thanks miata...I did called them up to check if they could do it.....they say it takes one day and typical cost about RM500....is this pricing good?...and do they do a good job?......I woorried that they will just give me a turbo unit from chop shop instead of rebuilding mine.......I don't intend to change the blades as you have mention the lag....they reason for ceramic is lightweight and heat resistant.....similar reason why ceramic used for brake pads......
when you brought your turbo to tong turbo....did you bring the entire turbo unit with the waste gaste as well as attached tubings(for oil and water)?.....would they clean out any clog in the oil return tubing?...do you have to replace the oil return lines as well as gaskets for the tubings as mention in the workshop manual?....
thanks.
Write your reply...
