where to get??
servo
Guys???..hardware shop??..how much for a can hah??
http://www.duplicolor.com/gallery/gallery_images/can_engine.jpg
Both Engine Enamel and High Heat Paint formulas now contain ceramic resins for maximum heat dissipation and gloss retention. The resins also offer protection from exposure to excessive heat and automotive fluids. Developed and tested in the lab, Dupli-Color® Engine and High Heat Paints will perform to the most rigorous standards of racing and street rod enthusiasts.
Dupli-Color® Engine Enamel with Ceramic
Resists temperatures up to 500 degrees F
Durable ceramic formulatio
Superior high gloss finishes
Oil and gas resistant
Will not blister, flake, crack or peel
36 colors matched to OEM standards
6 Classic Colors, 7 Hot Rod Colors
EZ Touch® Nozzle
Dupli-Color® High Heat Paint with Ceramic
Resists temperatures up to 1200 degrees F, intermittently
Durable ceramic formulation
Tough cured finish resists oil, gas grease, rust, salt, humidity, and solvents
6 colors
EZ Touch® Nozzl
thinking to heat treated my intake pipe so the piping doesn't get hot.
DIY HEAT TREATED INTAKE PIPE (found on net)
first, I washed the pipe twice, first with mild soap and scrub any where i can, then washed off with water.
and then I went a head and took the clear-coat stuff off with Steel Wool
http://www.superhonda.com/photopost/data/2/68725DSC05494-med.JPG
after scuffing the whole pipe out-side, I washed it agian with soap for painting process.
The sprays I used. (the spray on the right is the same stuff I used on my badge
http://www.superhonda.com/photopost/data/2/68725DSC05496-med.JPG
make sure the pipe is completely dried before spraying the primer.
http://www.superhonda.com/photopost/data/2/68725DSC05499-med.JPG
that's two layer's of primer. I loved the look of it just primed, but it had to be heat threated.
and then the heat-treatment stuff
http://www.superhonda.com/photopost/data/2/68725DSC05529-med.JPG
http://www.superhonda.com/photopost/data/2/68725DSC05533-med.JPG
looks like matelic colour???
very good bonding??
can it spray to y wheel???
also wanna know where to buy it!!
wah nice painting man.... really cool.... where to get it and how much? :P
no ones know where to get the paint ka???? :( .......maybe someones that across this paint at hardware shop.....???
at least will look like AEM & ICEMAN intake pipe.......well....heat treated.. :D
ICEMAN
http://www.geocities.com/allan_motol/iceman.gif
AEM
http://www.geocities.com/allan_motol/aem.jpg
wah nice paint job ler.. buy old second hand rim then spray them with these. :lol:
if cannot find got international shiping or not?
Originally posted by khguan@Jan 4 2005, 19:59
have u guys try searching in Ace Hardware? they have a wide range of paints..
bro...where is Ace HARDWARe???.......anyone else??still can't find this thing la..... :(
ace hardware in MV has a limited of DUPLI COLOUR products..
well there is DUPLI COLOur ENGINE paint in the 'OIL section' not the paint section
you'll see it hidden underneath..2 colour avail..orange and black
Write your reply...
