Who carried Mother around KK?![]()
None. I alwys buy in KL or in Aussie.
unless ur doing 300 for a period of time (i highly doubt that on malaysian roads) it'll be ok. it is only when u attend trackdays or drags that u need to actually reduce tyre pressures accordingly...[PIMPIN];3733117 said:Eh guys, I was being serious. I have never given this much thought and I know its dangerous but I did not consider running different pressures for high speed runs.![]()
What rating? Y? ZR?
guys...what's so special about meguire's?
1. Where's a good place to send this car for service/mods around Subang Jaya/Sunway/Shah Alam are? (specific garage)
[PIMPIN];3734536 said:I'm going to recommend a place which has done all my cars, even my parents cars - both audio and alarm systems. I believe in their workmanship and after sales support. Look for Peter Chong at CV Audio in Damansara Utama.
Tell him Razlan sent you. He's very thorough and always has the time for your questions, queries and special requests. But remember, a proper comprehensive alarm system does not come cheap. All those alarm systems going for RM899 lah or whatever do not offer you the protection you need. Spend a bit more, you will thank me for it.
If you want someone to hold your hand, I can come down to CV with you and introduce you lah hahah![]()
Hey...another friend of mine also recommended the same place. Actually i'm going there tomorrow.
No need to hold hand....but thanks for the offer though.![]()
Welcome to the FUN club Azmir.
CV AUto is a good place for alarms and audio systems, my regular place too. Just be prepared to grab a chair and sit down to enjoy hours of explanation on a particular alarms setup. He will be your perfect buddy thru out the entire installation.
Start with all maintenance fluid change...drive it for a few weeks to get to know the car better first.
Tire pressure depends on what tyre yours is fitted with, from my experience with soft sidewalls will be around 34-36 psi and harder sidewalls will be 32-34 psi mainly for town driving. If for the usual Blast i will up 2 psi all round for sharper handling.
Hope this helps in you enjoying your wild ride. Cheers bro!!
i've driven my Z out in trackday once only so my experience on underinflating the tyres are limited to 15inch n 16inch tyres cos when i was active participating in trackdays 3-5 years ago, my car n most other cars that i drive were using 15 n 16inchers.Correct me if I am wrong, but normally one would run a slightly higher pressure on track to optimize the tire capabilities ... I do know, the pressure would go up upon increasing tire temp but underinflating would never get your tires hard enough to work the suspensions. That's my thoughts though. And normally out track session would last max, 5-8 laps before pitting. Don't think many have tried more than 10-15 laps at one go?
Other thing is, the recommended max pressure stated on the tire sidewall would indicate cold, unless others have different thoughts?
haha...got reason to tell wifey if wana go faster, have to install oil cooler.....she will approve yr budget....azmir, that's normal if you are not running an aftermarket oil cooler. Time to put that into your shopping list. :P
azmir1,very supportive wife u got....*envy*. btw, how come yr car still being advertisted by the dealer on motortrader? or izit a different car?
