What are these meters for
r0yEE
Hey guys, i just want to know the specification on this meters listed below. just to have a sure confirmation.
what is a:
-vacuum meter
-water temp
-oil temp
-oil pressure
-fuel pressure
-air fuel ratio
-exhaust temp
meters for?
please list down the specs too. thankz very much..
what are these meters for?
what is a:
-vacuum meter
-water temp
-oil temp
-oil pressure
-fuel pressure
-air fuel ratio
-exhaust temp
meters for?
Re: what are these meters for?
-vacuum meter - to read vacuum level
-water temp - to read water temperature
-oil temp - to read oil temp
-oil pressure - to read oil pressure
-fuel pressure - to read fuel pressure
-air fuel ratio - to read air fuel ratio
-exhaust temp - to read exhaust temp
:banghead:
uh huh..
what's the vacuum meter for?
water temp for what?
and all of those..
for sure is for the engine's health.. i just want to know it specifically..
as for exhaust temp meter, u can know the Mixture Ratio is correct or not or any prob from exhaust temp.
vacuum is see ur compression in the engine normal or not...erradict compression spells breakdown or piston ring kong...
water temp stended car also got...see radiator in normal temp...too high means radiator gonna blow
oil pressure is oil pressure in the engine lah...dunno how to explain but when u accelerate, ur oil press goes up too....follows the rev n oil circulation...shudn't be too high
oil temp is temperature of the oil...if too hot, means ur driving habit requires u to get an oil cooler
try wikipedia
from oil press meter, u can get to know when is the exact time to change ur engine oil even haven't done 5000km....
+vacuum meter
A vacuum gauge is to measure the pressure in a vacuum so it's usually presented in (-). A low vacuum reading indicates a leak of vacuum.
+water temp
This gauge is used to monitor your coolant temperature. Also to tell you when your engine reach operating temperature. When a water temp is low all the time, this means that your thermostat might be opening too early (except for those who change them to low temp thermostat) or the water temp sensor is faulty. If temp too high. Thermostat might have stop working, lack coolant or tell you it's time to change to KOYO 3 core radiator.
+oil temp
This is to monitor your oil temperature and tell you when your engine oil is overheating. If oil temp is very high suggest installing an oil cooler to keep oil temp in check.
+oil pressure
This is to monitor the oil pump working condition. If the oil pressure drops too much. This means that oil pump is not working at it should be or there's no oil. If pressure too high it means there's a clog in the oiling system.
+Fuel pressure
see here: http://www.geocities.com/jonnyguru/vw/fpressure.html
+ Air fuel ratio gauge
The function of this meter is to let you know the AF ratio of the car. Similar to EGT gauge.
+Exhaust temp or EGT gauge
Is used to monitor the exhaust gas temperature of a combustion engine in conjunction with a thermocouple type pyrometer. by monitoring EGT, the driver can get an idea of the cars air to fuel ratio. Low temp = rich mixture, high temp = lean mixture.
+Boost meter
Is used to indicates manifold air pressure of turbo or supercharger boost pressure in an engine.
It's also used to ensure excessive pressure is not being generated when boost pressure is being increase to levels higher than OEM standard on a production turbocharged car.
cool..
thankz guys for the info.. now i'm all clear with the meters and gauges...
what's a RSM meter for??
cool..
RSM also stands for Rev Speed Meter. It shows your engine's revolution in digital form and act as add on tachometer for rev above what the OEM tachometer can show. It's also a speed cut device which means that you can go over 180km/h with the use of RSM as most JDM models the top speed is 180km/h.
It has alot of other functions such as:
Travel Distance, Battery Voltage (All which can be displayed in real time graph mode, numerical mode, or analogue mode; 1-4 channels at a time), Peak Hold, Replay (With 60 second playback), 0-100m, 200m, 400m times with trap speed, 0-100km/h, 200km/h, 300km/h – 0 times, user defined Mid Range Acceleration, Stop Watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM and Speed Outputs (For external devices requiring an RPM or speed signal), Tire Size Correction (For acceleration and timing accuracy). And Vehicle weight input. The new version of RSM has a G force function but you need to get the G-sensor. It measures G forces in 4-way front/rear/left/right directions. This data can be plotted in a graph display to map acceleration characteristics and lateral G’s on the race track.
Hope this helps you.
well it helps out a lot peeps.. thankz much guys..
Bump: well it helps out a lot peeps.. thankz much guys..
now i'm just thinkin
Bump: thinking of what meter to put in my ride:confused:
show ur battery condition loh~~~aiseh~~~u don't tipu tipu dont know lah~~:biggrin:
true la bro, i really dunno ma... hehe..
saw some of the mod car, they got 2 difren Volts meter, thats why i dunno ma..
just explain to me more details ma... pls...
can you explain more detail on this? how do we check?
i'll come back with more details... now busy... sorry...
How about a boast meter :confused::hmmmm:
Boast Meter..?? i oso confuse dy..:confused:
hahahha.. tell me about..
water temp meter we already have our stock ones rite?
the only meter i need now is a speedometer.. which is pretty hard to find a small one.. and i've to change my tachometer in future.. it ain't freakin accurate.. shit!! and it's auto gauge one.. ishkk:banghead:
