Wanted parts for sale...
skylinez
Guys I'm looking 1 set of Caliper and Disc rotor for front only from GTS-32 to be replace on my N16. Give me the good price and I will consider for it.
R32 GTS RM450 ..
complete front Rotor + caliper
you need to skim up to 278mm to make it fit
will the disc be extra fragile and more prone to wrap?
the skimming the into a smaller diameter has not effect to the rotor?
That one i have no idea le
just to tell you that you need to skim 2mm only
cmng...can reduce the price a bit or not RM300. My budget so chip la...if can, confirm I 'll take from u...boleh ka? Got any shop recommend can do a skim
300 cannot .. 400 best offer
by the way.. forget about the skim thing first
make sure your rim can fit before you do it
later sudah buat rim cannot fit . jia lat
unless you using S14 4 pot
cmng,
I'm using nissan N16 1.8 GXE. My sport rim is 15"(PCD 114.3) original from nissan Tan Chong from Japan...so can fit or not?
Gulp!....aiyo...budget for rim some more...fuh!!!!!!! :wacko:
yupp. that why check teh rim clearance before you fit
15" should able to clear S14 4 pot if it have right offset
i don have any idea on N16 1.8 rim wide and offset clearance
thanks cmng...i apppreciated ur guide...that means I have to look and try to fit with my 15" sports rim.
no.. just get the yuor N16 1.8 rim size first
or change rim la..
or change to 2 pot brake instead of 4 pot
nissan got twin pot caliper?? :unsure:
as i know, nissan only have single pot or 4 pot... :unsure:
btw, S14's stock rim is 15"?
Emm
so far i found it at U13 turbo.
possible on W11 turbo as well
hi.. wanna to ask..
N16 1.8 come with ABS, so if we change the disk+++++,
will it effect the function of the ABS.
sorry nob here, thanks
