some part for sale
cmng
Sorry tom.
since feed back can be more from here
dont mind if you towed it
Used Cusco Caster rod for A31, R32, S13, S14 bla bla
Rm250 a pair
2 pair available
Used Cusco Negative Upper Arm ( err for skyline R32 wishbone )
RM 250 a pair also
2 pair available
Buying both together RM400 a set
R32 rear axle ( complete rear axle for 5 lug and 2 pot conversion )
OEM viscous LSD + driveshaft
Nissan R32 GTS 2 pot rear brake
Nissan R32 GTS 4 pot front caliper as well
RM 1k
for A31,S13 and 180sx, you just need convert the front to 5 lug or S14 knuckle to complete 5 lug conversion and 4 pot front and rear
condition for all part mentioned above is good
all brake caliper have brake pad as well oem brake hose
Original for RB20DET R32
suitable for A31, S13 with RB20DET or RB25DET conversion as well
Trust IC + piping
Piping is side thru
Core is 425 x 276 x 3" need to comfirm
come with all the neccesary silicon hose and clamp
IC piping got flange for trust type S bov ( no bov, bov is removed )
Trust Air filter + trust adapter ( big adapter ) for RB20DET kit
RM2000 for IC+ IC piping + Trust filter + Trust adapter
Price is negotiable
interested call me at 019 2721883
Thanks
:) the cusco camber rod for the rear or front aaa?Interested if it's the front.
Front la
if rear you think i can sell meh . sure kena bamboo lo
bro this one is the black half cut issit?
I might have a buyer for the engine
can you tell "the boss" to hold first..
i will confirm with him end of today
thanks!
nope.
only the camber and castor is from the halfcut
the rest is from another halfcut just arrived yesterday at his shop
sorry...
some correction on the part thing
i miss understood of the part . especially camber rod.
it is negative upper arm
The pic is below
the blue colour arm stuff
those have booked .. please check back
castor rod remain same.
got few brand
ARC ( darn not ARC cooler maker but other japan brand )
TIEN
Cusco
dude you re-sprayed those caster /tensional rods ay?? still good ones rite..?? as mention earlier my friend want's em all hehe
for the nismo lower arms... wot's the diff between the stock ones?? solid / bearing mounts? something else.?
bro.. not sprayed.. as good as you see
RM250 you ask me to waste my time to spray that thing meh
not worth the time and the cost to spray la
unless RM1k maybe ok la.. spray spray it la..
That nismo lower arm.. any different ?
no idea but i comfirm that is lighter only
by the way, it not for sale since taiko want it on his car
