Vifa XT25SC+ 6.5" Component set
ICE -In Car Entertainment
lmh77
http://s.lowyat.net/uploads//attach-58/post-110158-1278560338_thumb.jpghttp://s.lowyat.net/uploads//attach-58/post-110158-1278560366_thumb.jpg
Vifa from Denmark
1" Dual Concentric Diaphragm with Ring Radiator Tweeter
The smaller-sized features a patented dual concentric textile diaphragm and a unique waveguide center plug that provide an excellent on- and off-axis response.
The goal for this tweeter series was to create a transducer that has a frequency response that is flat to above 20k, and where the distortion is far lower than normal and more friendly to the ear.
The XT tweeters are acclaimed for their very natural sound with an extremely smooth frequency response extending well beyond the human hearing range.
* > Dual ring radiator diaphragm (patented)
* > Waveguide center plug (patented)
* > Neodymium magnet with heat sink
* > Flat response well beyond 20 kHz
* > Copper-clad Aluwire Voice Coil
* > Phage Plug with Ring Formed absorption chamber
* > Low distortion
Visaton
6.5" MidBass from German
Model: W170S
Technical Data:
Rated power 50 W
Maximum power 80 W
Nominal impedance Z 4 Ohm
Frequency response fu–8000 Hz
(fu: Lower cut-off frequency depending on cabinet) .
Mean sound pressure level 86 dB (1 W/1 m)
Opening angle (-6 dB) 72°/4000 Hz
Excursion limit +/−10 mm
Resonance frequency fs 36 Hz
Magnetic induction 1,0 T
Magnetic flux 314 µWb
Height of front pole-plate 4 mm
Voice coil diameter 25 mm
Height of winding 12,5 mm
Cutout diameter 148 mm
Net weight 1,1 kg
D.C. resistance Rdc 3,2 Ohm
Mechanical Q factor Qms 2,16
Electrical Q factor Qes 0,51
Total Q factor Qts 0,41
Equivalent volume Vas 38 l
Effective piston area Sd 129 cm²
Dynamically moved mass Mms 12 g
Force factor Bxl 4,4 Tm
Inductance of the voice coil L 0,6 mH
http://s.lowyat.net/uploads//attach-58/post-110158-1302513189_thumb.jpg
Condition: NEW
Price: RM520 for all
XT25SC Vifa Tweeter + Visaton 6.5" MidBass + Passive X-Over
Contact: 012-9142998 (Lim)
Good review for Vifa Tweeter!
index.php
:love:
BUMP.
Price can Nego.!
Call: 012-9142998 (Lim)
