Part for sale
SR16VE, SR20VE metal gasket
1.1mm Thickness
Fit SR20DE/DET FWD
RM600
SR16VE NGK plug cable
Blue colour.
Good Condition
With full copper wiring at the cable
Only fit SR16VE and SR20VE
RM200
SR16VE gearbox
LSD gearbox
Driveshaft not included
RM1500
SR16VE Radiator with Fan
Single Core
RM150
SR16VE AC pump
RM 200 3 unit available
SR16VE Alternator
RM80 2 unit available
SR20VE complete wiring
Come with Auto gearbox wiring and gearbox ECU
Come with Main ECU
RM1000
Stock SR16VE ECU
RM500 2 unit available
SR20VE ECU Rev Cut 8000rpm
RM800
N16 knuckle
Come with A32 disc and rotor
Direct bolt on to B13, B14 for 114.13 x 4 pattern
280 x 22 mm rotor size
RM650 1 set
N16 Knuckle
PCD 100 x 4 . very rare
Direct bolt on to B13, B14 for 100 x 4 pattern
can bolt on Nissan Twin pot, A32 big Disc and rotor
Just the knuckle only RM 400
SR20DE gearbox
LSD gearbox
Cable Type
RM 600.00
Used Nismo 0.8mm Metal gasket for SR20DE/DET FWD
RM200
Brand new SR20DET GTIR Piston, Con Rod and Piston Ring for sale
RM1600
This is Brand new Item unused
And many many SR16/20VE/SR20DE/DET part available which I forget as well
Clearing my storeroom.. Too many item
Interested please call
019 272 1883
Thank you
1.1mm Thickness
Fit SR20DE/DET FWD
RM600
Blue colour.
Good Condition
RM200
SR16VE gearbox
LSD gearbox
RM1500
Single Core
RM150
SR16VE AC pump
SR16VE Alternator
Come with Main ECU
RM1000
Stock SR16VE ECU
RM800
N16 knuckle
RM650 1 set
N16 Knuckle
SR20DE gearbox
LSD gearbox
Cable Type
RM 600.00
RM200
RM1600
019 272 1883
Thank you
