Used Bm Boschmann Amplier, good for sub
1. Used Avantgarde valeraine amplifier with upgrade burr brown -SOLD
-Add another RM100 for 2 x 30A cryo fuse.
-4 Channels
60Watt RMS per Channel @ Stereo 4 Ohms
90Watt RMS per Channel @ Stereo 2 Ohms
150Watt RMS per Channel @ Mono 4 Ohms
T.H.D. <0.05% @ 4 ohm
Frequency response: 20Hz – 20kHz
>90dB Signal to Noise Ratio
>50dB Seperation @ 1kHz
0.2V – 4V input sensitivity
20kOhm Input Impedence
Damping Factor >150
Dimensions: 370 X 58 X 210mm
Weight: 3.33kg
-I used to own steg aq 75.4 and this amp is simply better.
Valeraine VX-2i active crossover
2. Used Alpind dd drive 12" woofer DDW-F30A include seal box-SOLD
3. Used BM Boschmann PCH-990ATX 2 channel amplifier - RM 330
Specification:
Impedance: 2Ω stereo, 4Ω bridged
Power rating: 2 x 900W RMS into 2Ω, 450W x 2 into 4Ω 1800W max bridged into 4Ω
Freq response: 10Hz - 40kHz
Channels: 2/1 bridgeable
Input sensitivity: 200mV to 2V
Low pass filter: 40Hz to 150Hz
High pass filter: 150Hz to 1.2kHz
Remarks: 1 of terminal has been replaced by aftermarket screw but it doesn't affect the performance, work like charm, can test kao kao before purchase.
Kindly sms/pm Dickson-0122042666 for fast deal.
-4 Channels
Damping Factor >150
Weight: 3.33kg
Specification:
