Upgrading 20v
chinozie
Very Young Member... :D
Damansara
Saw this movie, "Togue 200 class" where Keiichi Tsuchiya drift car - AE86 versus Spirit MR-S
then saw this Motore AE86 Levin...with 20V BT engine...
here are the specs...
Engine : 180ps
Cams : Intake 272, exhaust 288
Pistons : 0.5mm overbore
ECU : Freedom ECU x2 (twin injectors)
Headers : Full Original
Exhaust : Full Original
Final Drive : 4.5
LSD : TRD
Dampers : Race Spec, F - AE92 short, R - AE86 short
Brakes : F - MZ20 , R - Stock
Pads : F - Project U B-spec , R - Project U Titan
Tyres : Potenza RE01 195/50/R15
Other : Imota Special Bodt Reinforcement
Weight : 910Kg
______________________________________________________________________
The questions are :
Q01 -> Cams : Intake 272, exhaust 288...are they the same with 20V SVT engine ?
Q02 -> ECU : Freedom ECU x2 (twin injectors)...why 2 ECUs...Japan ppl kaya oledy aaa, put 2 ECUs :D
Q03 -> Final Drive : 4.5...what's the 20V SVT stock final drive...how to mod it? what effects ?
Q04 -> Dampers : Race Spec, F - AE92 short, R - AE86 short...why they use shorter one...?
Heee...sorry toomany question...just wanna gain knowledge from the Sifoossss...
Thank You...
2. May be two ECU calculate thing faster? hahaha...
4. i think it means short stroke.
Q2=1 Freedom ecu only.......maybe thats the version...
Q3=yeah sure can....blardy expensive n u will lost top speed.
Q4=short=short stroke........do a reading or search in the net about this.!!
Q2 , it really show Freedom ECU x2...then why twin injectors...got onather version of Wbber aaaa...:D
any way thanx man...
TT shall we ?
Q01 -> Both Blacktop and Silvertop shares the same Cams Design, just the profiles are a bit dfferent.
Q02 -> Freedom ECUs are cheap in Japan itself.
Q03 -> Stock Final Drive for C56 and C52 is 4.3
Q04 -> Short Stroke Dampers offers less rolling factor compared to normal stroke.
final drive shiok....... trd final drive is 4.733..... ori 4.312....... very big difference.... but too expensive thats why i go for 6sp...... if i got the budget.... go final drive.... u don't lost top speed really.....4.312 top speed is 260 at 7k rpm.....4.733 top speed at 210-220 at 7k rpm
normally all the car got speed cut at 190kmh so make no diff......diff is rpm is higher than normal and u will feel petrol consumption higher abit.... but all kaki lumba dun care about petrol consumption..... only uncle do that
yup uncle car...
but i'm just gaining knowledge...
but who know's one day, i stuck with one sugar 'mummy' :D...
wahhh alvin, your car topspeed is 260km/h ????? ahhhhhh????
so fasttt,,,,
Question 2:
It uses 2 ECU mainly because is want to run 2 bank of 4 injectors which totally of 8 injectors. 2 injector/ cylinder. Running 2 ECU can run both injector in different map. Maybe 2nd bank is running peak and hold injector or something.
There is a few 3 rotor 20B running with 3 ecu to make things easier then trim the settings accordingly.
Write your reply...
