BuddyClub, MOTEC, HONDA B20 Race Engine, WELD Drag Rims
ANY INQUIRIES PLEASE CALL 0123352226,
Buddy Club Spec V cams Used less than 5km on race car only RM2X00negReduced Price,
Duration
Intake - 312
Exhaust - 306
Valve Lift
Intake - 12.80mm
Exhaust - 11.80mm
Motec CDI 2 units RM1500Neg per unit. Used unit comes with Wiring & new Unit comes without wiring.
https://www.zerotohundred.com/forums/attachments/187043.vB,
Crane PS92 CDI coil to be used with Motec CDI. RM500neg
https://www.zerotohundred.com/forums/attachments/187046.vB,
VR4 injectors RM 300
ACT CLUTCH cover and unity organic disc with exedy flywheel( tested on a 440WHP vtec turbo boosting at 2 bar with no slip) RM 1100neg.
SUPER LIGHT DRAG WHEELS - Weld Racing Racelites 13 X 8, PCD 5 X 100, 2.73Kgs per piece plus M&H Drag Tires Tubeless 23 X 8 inch. - RM 2000 for the set.
http://image.importtuner.com/f/features/8368554+w200/0308scc_18weldracracelirs_z.jpg
B16A Pro Race Ported Head, Type R Valves, Type R LMA/ Pivet, Type R Rocker Arms, Valve Angle done ( This head has done 248WHP ). RM 2XXX.00 neg.
B18CR Pro Port Head, Oversize Valves, Type R LMA/Pivet, Type R Rocker Arms, Valve Angle done RM 2XXX.00 neg
B20 Block - 86mm bore, 87.2mm Type R Crank balanced, CP 86mm forged pistons and rings(Used less than 5km old), ENDYN Block Brace. Type R Rods + rest of the accessories on the block Call for Price.
B20 Block - 86mm DC5 Type R Pistons, 89mm lightened & balanced crank by moris, stock b20 rods, Block Girdle Type R + line bored plus other block accessories. Call for Price.
If you have any inquiries please give me a call or text me at 012 335 2226.
BUMP If you think the stuff is cool. tq
Duration
Intake - 312
Exhaust - 306
Valve Lift
Intake - 12.80mm
Exhaust - 11.80mm
