toyota 3tgteu head gasket
MYKE70
hi,
anyone know where can i get head gasket for 3t gteu twin spark turbo?if have kinly pls pm me or leave ure contact no...
thanks...
wow! never knew anyone playing this engine for longtime.
Try 2tg gasket;may not be same because of turbo/heat application.Try any of the toyota parts suppliers?
If absolutely no choice,then try a piece of aluminium cut to shape=metal gasket!
Good luck
bro 1jtezza,
already used 2t gasket same as 3t but power lossla bro..:banghead:
where can custom made aluminium head gasket?n what is the thickness?
thanks bro..
maybe 1mm to 3mm and get a machine shop to cut out the oil and water holes and pay particular attention to the cylinder/piston areas.You may also need new cylinder head bolts to torque down this new gasket as the old ones could be stretched.
Just my 2 cents and hope it works/helps.
