The Bmw Engine Lists, Specs And Faqs
  • Thread starter Tom
  • Start date
  • Replies 16
  • Views 65K
T
Tom
Guest
By:
Chapel
www.mwerks.com
Horsepower quotes may not always reflect US Rating
If there are two HP numbers, lower HP number generally denotes US rating
M10 - Straight 4 cylinder SOHC 8V. 1966-1987. 83kg 180lbs
Used in 1502, 1600-2, E21 316/318i/320-4, E30 316, 2002tii and 2002 turbo
1.5 (75bhp), 1.6 (85bhp), 1.8 (90-98bhp), 2.0 (100bhp), 2.0i (125bhp), 2.0tii (130bhp), 2.0turbo (170bhp)
M20 - Straight 6 cylinder SOHC 12V. Baby Six. 1977-1992. 117kg 258lbs
Used in E21 320, E21 320i/6, E28, E30, E34, E21/30 323i, E30 325e and E28 528e
2.0i (129bhp), 2.3i (143bhp), 2.5i (170bhp), 2.7e (125bhp)
M30 - Straight 6 cylinder SOHC 12V. Big Six. 1973-1993. 143kg 315lbs
Used in E12 525/528, E28 525i, E23 725i, 2800CS, E28 528i, E23 728i, 3.0CS/i/L, 3.0Si, E12 530i, E23 730i, 3.3Li, 633, 732i, 733i, 535i, 635i, 735i, E12 M535
2.5i (150bhp), 2.8i (184bhp), 3.0 (185-208bhp), 3.3 (200-206bhp), 3.5 (218bhp)
M102 - Straight 6 cylinder SOHC 12V Turbo. Big Six Turbo. 1984-1986. 145kg 320lbs.
Used only in the E23 745i
3.2L or 3.4L Turbo (252bhp)
M40 - Straight 4 cylinder SOHC 8V. Replaced the M10. 1987-1993. 81kg 178lbs
Used in post 87 E30 316i/318i, E34 518i, Pre 93 E36 316i
1.6 (102bhp), 1.8 (122bhp)
M42 - Straight 4 cylinder DOHC 16V. 1989-1996. 100kg 220lbs
Used in E30 and E36 318is, Z3
1.8 (138-142bhp)
M43 - Straight 4 SOHC 8V. 1993-1998. 83kg 183lbs
Used in post-93 E36 316i/318i, E34/39 518i.
1.6 (102bhp), 1.8 (115bhp)
M43TU - Straight 4 SOHC 8V. 1998 on. 83kg 183lbs
Used in E46 318i
1.9 (118bhp)
M44 - Straight 4 DOHC 16V. 1996 on. 102kg 225lbs
Used in E36 318iS, Z3
1.9 (142-150bhp)
M50/M50TU - Straight 6 DOHC 24V/Straight 6 DOHC 24V with Single VANOS. 1989-1998. 136kg 299lbs
Used in E36 320i/325i, E34/39 520i/525i, Variation of this was used in the Early US E36 M3
2.0 (150bhp), 2.5 (192bhp), 3.0 (240bhp) Sometimes referred to as S50US. Engine shares more common parts with M50 than Euro S50, but is a motorsport engine.
M52/M52TU - Straight 6 DOHC 24V with Single VANOS/Straight 6 DOHC 24V with Double VANOS. 1996-1999. Iron Block in US, Alloy Block in Europe. 118kg 260lbs (alloy) 140kg 308lbs
Used in E39 520i/523i/528i, E36 323i/328i, E38 728i, Variation of this was used in late US E36 M3.
2.0 (150bhp), 2.5 (170bhp), 2.8 (193bhp), 3.2 (240bhp) Sometimes referred to as S52US. Engine shares more common parts with M52 than Euro S50, but is a motorsport engine.
M54 - Straight 6 DOHC 24V with Dual VANOS. 2000-present. 126kg 277lbs
Used in late model Z3, all E39 and E46 six cylinder models
2.0 (150bhp), 2.2 (170bhp), 2.5 (184-192bhp), 2.8 (193bhp), 3.0 (231bhp)
M56 - Straight 6 DOHC 24V Dual VANOS with ULEV. 2002-present. 127kg 280lbs
Used in some E39 and E46 six cylinder models
2.5 (184bhp)
M60 - V8 DOHC 32V. 1992-1996. 146kg 321lbs
Engine blocks were made of Nikasil (Silicone Injected Nickel) which were prone to failure over time. Many have been replaced with the newer Alusil (Silicone injected Aluminum) engines/
Used in E34 530i, E32 730i, 740i, 840i
3.0 (218bhp), 4.0 (286bhp)
M62/M62TU - V8 DOHC 32V/V8 DOHC 32V Single VANOS. 1996-present. Alusil Engine block. Pre 98 engines were non-VANOS. 140kg 308lbs
Used in E38 730i/740i, E39 540i, X5 and 840i
3.5 (235bhp), 4.4L (286bhp), 4.6 (340bhp)
M70 - V12 SOHC 24V. 1988-1994. 155kg 341lbs
Used in E32 750il, 850i
5.0 (300bhp)
M73 - V12 SOHC 24V Single VANOS. 1995-2001. Pre 98 engines were non-VANOS. 150kg 330lbs
5.4L (326bhp)
http://www.unixnerd.demon.co.uk/s14.jpg
S14 - Straight 4 DOHC 16V Solid Lifter Valvetrain and Individual Throttle Bodies. 1987-1991. 106kg 234lbs
Used in the E30 M3 and Italian only E30 320is
2.0L (195bhp) 2.3L (192-200bhp), 2.5L (215-238bhp)
http://www.unixnerd.demon.co.uk/s38m1.jpg
Original S38 (Also known as M88 and M88/3)- Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1979-1980, 1986-1990. 146kg 321lbs
Used in M1, E28 M5, M6, SA E23 745i
3.5L (277-286bhp)
http://www.unixnerd.demon.co.uk/s38.jpg
Updated S38 - Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1988-1996. 151kg 332lbs
Used in E34 M5
3.6 (315bhp), 3.8 (340bhp)
http://www.ne.jp/asahi/kitaho2/bmw-m3smg/e36engine-s50-01s1-00.jpg
S50 - Straight 6 DOHC 24V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies. (Dual Vanos on 3.2Ls) 1992-2000. 152kg 333lbs
Used in non-US E36 M3
3.0 (286bhp), 3.2L (321bhp)
http://undergrad.nova.edu/kevin/s54-EngineWhole.jpg
S54 - Straight 6 DOHC 24V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 2001-present. 148kg 326lbs
Used in the E46 M3 and the last of the Z3 M-Coupe and M-Roadster.
3.2 (321-343bhp)
http://www.unixnerd.demon.co.uk/s62.jpg
S62 - V8 DOHC 32V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 1999-present. 158kg 348lbs
Used in E39 M5 and Z8
4.9L (400bhp)
S70 - V12 SOHC 24V. 1995-1997. 165kg 363lbs
Used in 850CSi
5.6L (380bhp)
http://autozine.kyul.net/classic/mclaren/f1_eng.jpg
S70/2 - V12 DOHC 48V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies
Used in McLaren F1 (Was originally developed for M8)
6.1 (627bhp)
M21 - straight 6 SOHC 12V Diesel. 1983-1991 126kg 278lbs
Used in 324td, 524d/td
2.4 (112bhp), 2.4 Turbo (115bhp)
M41 - Straight 4 SOHC 8V Diesel. 1995-on. 108kg 238lbs
Used in E36 318tdS
1.7 Turbo (90bhp)
M51 - Straight 6 SOHC 12V Diesel. 1995-on. 132kg 291lbs
Used in E36 325td/S, E34 and E39
2.5 Turbo (115bhp), 2.5 Intercooled Turbo (143bhp)
M47 - Straight 4 DOHC 16V Diesel. 1998-on. 117kg 258lbs
Used in E46 320d
2.0 Turbo (136bhp)
M55 - Straight 6 DOHC 24V Diesel. 2000-on. 132kg 291lbs
Used in E46 and E39s.
2.5 Turbo (170bhp), 3.0 Turbo (183bhp)
M67 - V8 DOHC 32V Diesel. 1999-on. 192kg 423lbs
Used in E38 740d
4.0 Turbo (245bhp)
N44TU - Straight 4 DOHC 16V Dual VANOS with Valvetronic
Used in E46 318i
1.6 (115bhp), 1.8 (143bhp)
N62 - V8 DOHC 32V Dual VANOS with Valvetronic
Used in E65 745i
4.4 (325bhp)
N73 - V12 DOHC 48V Dual VANOS with Valvetronic
Used in E65 760i
6.0 (438bhp)
http://www.bmwworld.com/pics/mini/4981_832.jpg
W10 - Straight 4 SOHC 16V
Used in Mini One, Mini Cooper
1.6 (90-115bhp)
W11 - Straight 4 SOHC 16V with Eaton Supercharger
Used in Mini Cooper S
1.6 Supercharged (163bhp)</
How come the M40 1.8 is churning out 122bhp? Most websites/literature I see rate the engine at 113bhp........
i think the E46 318i is N42TU
which will be 2002 onwards E46 318i.. Double Vanos.. 143bhp...
and then in 2004, they introduced a revised version of this N42TU which is the N46TU...
key differences is also the management system..
The N42TU has 1 computer seperate for control of the valvetronic system and the N46 now, the control unit is intergrated into the ECU but somehow, having driven this car, the N46TU power delivery feels worse and more sluggish...
hehehe
im not being bias cause mine is n42
i juz wanna ask....
im driving a bmw 525i......but its the old old 1
i dunno wht year model is it....i think its 1983...
wht engine is tht?
this car gives me alot of trouble......
the engine is overhaul.......but me parents got no mani to tune it up.....
hmmph.....
the spark plugs muz change and wash it ourselves.......at least once in 2 weeks
or not u step how hard on the accelerator ....the car also wont move.....hmmph.......
so muc trouble....
and also.....the coolant alwayz got overheated.......can u advice me on sumthin?
mayb adding coolant liquids? coz i scared the car might not b able to use it........later i put aledi then not suitable......then rosak....
hmmph......dilemma
:blink:
Just my 2 cents. No continental cars are advised to use any form of coolant. It will cause the radiator to rust plus this coolants are not good. I might be wrong but this is from experience lar. Try using water oni in Ur radiator. I hope this doesn't offend BMW fans but I'm actually a Mercedes owner. but I like BMW engines very much. I would appreciate it if U huys can share with me more bout engines. I drive a 190E, a very competent car in terms of handling, but not so good in power. I'm not saying it's bad, but it's just not a good as the Munich powerplants, as much as u wanna argue. Maybe because BMW uses vanos and DOHC technology. I'm looking 4 an 2-2.5 litre can be 4 to 6 cylinder angine which has performance. Hope U guys can help me la.
i like tat S62..izit fit in every BMW?wowo..S62 is nice..4.9l(400bhp)..tat's cool..how much is tat engine cost?
can anyone tell me..y is V8 having (400hbp) n v12 having only (320bhp)which 1 is nicer then?
i think the power is not everything..gotta look at the amount of torque it produces... :D
Can someone tell me if M102 will fit into E32's engine bay? I've found one at Puchong... price is nego at RM 2.5k for engine only. Still searching for suitable GB. As for management, might use standalone since the original ECU is missing.
tom, or anybody, just a quick question.
is there any difference between the E30 325i and 325iS engine model?
weight difference? and also, what are the typical mpg for both these engines?
Im confused , so the local assembled 328i is using m52 or m54 engine ? Hence single or double VANOS ?..
i wanna ask for a friend bout the m20 2.7 engine, what is the final drive for this engine? he put this engine in his e30.
Just want to know a bit of info, how about E46 318 (2000) engine code and feul usage & maintenance cause I in the process to get this model soon
heLo.. bro.. first thing sory yeah i speak maLay.. hehehe..
ok. my fwen baru beLi recond car BMW 320 E90. So, e90 banyak sensor.. Ini keta mau kasi sLamm pakai ebach coiL spring n tuka rim pakai 18inc.. So.. ada probLem tak pada sensor tayar or suspensein biLa sudah di tuka nanti..
Thanks..
Guys, a quick question
i have a 2001 e46 coupe, previously with a M43 engine ; now after my transplant, it's running a 6 cylinder cast iron engine (shall not mention as risk of blasphemy amongst purists) .
Anyways, this has caused my front to drop about an inch and a half, with the springs realllly compressed.
my question is this - will a set of eibach springs for an e46 330i help at all? and is it a straight fit? please let me know asap. Thanks!
T
Replies
Views
11K
