Suspension system on EK
Use SPOON babe....its tested for ur car. Worth it.
check out my link......
http://www.zerotohundred.com/newforums/showthread.php?t=122982
UKDMEK4 said:
finally i end up with koni soft hard+eibach pro kit :regular_smile:
may i know what is the spring rate for ur eibach ?
Currently used Bilstein Hi/Lo. people said German is good in suspension set up!!
currently using cusco hi-lo soft hard, which after u set the spring rate n absorber stiffness, u can still adjust ur ride height by adjusting the lower part of the abs without affecting the adjustment earlier that u done on the spring n abs. its like fully customizeable
