SLICK®50 available here!branded engine treatment
SLICK 50 engine oil treatment changes the surface metallurgy or ur engine's vital parts
As an engine accumulates mileage,it may not perform as well as when it was new, It may generate more noise, burn oil, and suffer from last performance and fuel economy.
SLICK 50 Advanced Formula Engine Treatment is compatible with all types of motor oil,is safe for all automotive gasoline engines, and will not void manufactures' warranties.
-PROTECTS AGAINST FRICTION AND HEAT.
Slick 50 Advanced Formula Engine Treatment contain unique and propriety Slick 50 Protection Chemistry, which uses specially prepared PTFE. It actually changes the surface metallurgy of ur engine's vital parts
-CARRIER OIL MEETS ILSAC GF2 AND API SJ GAOSLINE ENGINE OIL PERFORMANCE AND FUEL ECONOMY SPECIFICATIONS.
Slick 50 Advance Formula Engine Treatment contains a fully formulated 10W-30 carrier motor oil.
-WILL NOT CAUSE CORROSION OF ENGINE COMPONENTS
Slick 50 Advance Formula Engine Treatment does not contain any compounds that can cause corrosion in your engine. An indepedent laboraty performed two industry standard corrosion tests on the 4 leading national engine treatment brands and Slick 50 was the only engine treatment that passed.
50,000 mile engine limited warranty
Slick 50 has normally guaranteed your satisfaction within 30 days, or your money back. Now, when you buy a quart of Slick 50 Advanced Formula Treatment, you get a FREE 50,000 mile engine limited warranty if the mileage on your vehicle is 50,000 miles or less when you first use the product.
If your vehicle qualifies, you may simply fill out the enclosed warranty card and mail it to us begin your warranty, then follow the program outlined in our warranty. Slick 50 agrees to repair or replace the engine parts listed below that fail due to engine wear or which experience abnormal wear, subject to certain exclusions and limitation descride in the warranty
Of course, Slick 50 Advanced Formula Engine Treatment is not a subsitute for routine maintance. For the 50,000 mile limited warranty to apply, you still need to change the engine oil regularly at least every 4,000 miles or 4 months, whichever comes sooner and maintain your vehicle according to the manufacturer's recommendations. Pre-existing engine damage and other abnormal conditions are not covered.
rm110
others slick 50 product that i have:
Slick 50® Synchron® Synthetic Formula Engine Treatment mp rm110
Slick 50® Annual Automatic Transmission Treatment mp rm75
Slick 50® Manual Transmission Formula mp rm75
Slick 50® Power Steering Formula mp rm45
Slick 50® Gear Lube Formula mp rm60
Slick 50® One Lube® mp rm14
c the detail from the link below
main link
http://www.slick50.com/Product_Pages/Products.html
if interested kindly contact 012-2363293/016-3282268 for more information,location nearby jusco kepong,cc acceptable,msn contact [email protected], website:http://www.zhapalang.com.my
Partnering Sellers/Merchants:
>> http://zerotohundred.com/newforums/search.php?do=process&showposts=0&starteronly=1&exactname=1&searchuser=c-ground
>> http://zerotohundred.com/newforums/search.php?do=process&showposts=0&starteronly=1&exactname=1&searchuser=HMS
>> http://zerotohundred.com/newforums/search.php?do=process&showposts=0&starteronly=1&exactname=1&searchuser=Rock+Lee
rm110
main link
