Saga / Iswara Rear Brake Disc Solution
beztien
27
1,503
Guys... need some info here... Besides sv4 brake pump and putra 1.8 brake pump... What other brake pump that can go inside iswara? I mean the most effective one... Hehe..
steven7810
mivec user
1,314
26
kuala lumpur
hello is steven,
i just change the rear vr4 brake pad few weeks ago... is normal i order the supplier send between 1 hour....
can try fit in perdana,vr4 and others also can but need to change sport rims bigger size la
i got 1 friends modified myvi front disc brake to honda odessy... hahaha
ridzuan_81
67
Tawau
Hey guys,
why dont you all try to get Perdana V6 rear disc brake? another solution for iswara/saga. I've my one install few months ago.
wah this is good topic, v6 disk......
How about the bracket & hub? do u have mod of that? can i cut@mod my ori drum to fit perdana v6 disk? and the prob is bracket if want to fit with perdana v6 la. confuse with the thickness of the hub + disk........ lol... just share my fren
steven7810
mivec user
1,314
26
kuala lumpur
hi need a bit of advice, im planning to change my iswara front brakes to the wira front brakes. can i plug and play? do i have to change the brake pump and all? need advice. appreciate from the bottom of my heart :)
Bump: hi need a bit of advice, im planning to change my iswara front brakes to the wira front brakes. can i plug and play? do i have to change the brake pump and all? need advice. appreciate from the bottom of my heart :)
hi the wira screw hole are 100 and iswara are 114.3 so wat for... better go for vr4 or perdana or others... from steven 7810
steven7810
mivec user
1,314
26
kuala lumpur
hihihi is me again steven,, just change the front brake pad using vr4 super touring type brand lemburg rm 140... order like normal la just wait around 1 hours plus due to raining....
i got friend just install the nissan skyline to myvi 1.3 manual front only...
selamat berpuasa....
fitri_thiang86
1,183
7
any one got rear mirage disk...
plzz pm me,k...
hehehe....
i am using saga also...
front i am using waja...
ok or not?
Bern_91
12
erm.. to all sifu sifu.. putra rear disk can PNP,, den how bout front?? can?? change all to PCD100.. can?? sifu reply yar.. thx^^
yewwing
11
1,503
i dont think all the rear brakes can be pnp into iswara, is necessary to do a slight mod in order to install rear disc brake. the perfect option for iswara is full set perdana which u wont have headache finding parts or brake pad in future compare to mirage etc :D
qib_akip
286
KL & KUANTAN
bro, can PM me ur phone number? currently im using a saga with 4g92 mivec... but i have a few question if you can share with me...
May 5, 2014
johor
Perdana rear brake can fit to iswara la cheap
To install perdana rear brake to iswara..
col us 0127671974 (sundar)
ALFA MOTOR..
56,jalan ara 2
taman rinting
81750 masai johor..:wavey:
steven7810
mivec user
1,314
26
kuala lumpur
Bro.. iswara rear or front better use VR4 single pot 15 inch rims.if 2pot front 16 inch.....
And do cbange ur servo brake pump to bigger or use gsr double layer
steven 4g92
---------- Post added at 02:07 PM ---------- 6 hour anti-bump limit - Previous post was at 02:05 PM ----------
My iswara with Mivec 4G92 Black Top ecu 7035..
4 disc VR4..
steven 4g92
Hi fellow ZTHian, i have currently bought a water temp meter, but no idea on the wiring part,hope sifu can show me some guide:
I have the sensor install and go thru firewall
red, black, white n yellow wire
have check the under neadth of the dashboard, not sure how to tarik the wiring for 12V? can i sambung from the...
