S4pe convert to s4ph
blm8137
hello,
im using Saga Blm 1.3 and i am interested to convert it to 1.6.
i heard about changing stroker kit and several other parts to 1.6.
but i need a lil more specific info. is there any garage do this service or any other cheaper way like chop shop for parts etc etc..
thank you!
convert to mivec straight away...more power,more feel,more syiokkkkk~!!!hehehe
hello,
thank you!
jz get the crankshaft and throttle body....
re-ggurdss,
skywalker
u need block as well
different stroke...s4ph stroke 88mm...s4pe 73.4mm:idea:
pe --> ph
item to be upgrade :
1. crankshaft 1.6
2. con rod 1.6
else...remain unchanged....
i didnt know even the cylinder block itself has different length...
hmm im confuse here..
TB..
crankshft..
con rod..
block..
which one really LOL?:adore:
if the 1.3 and 1.6 block has different height, yes u need the conrod as well...
if 1.3 and 1.6 blcok is the same, u jz need the crankshaft
throttle body is additional to make ur engine breathe easier when u upstroke ur engine...
