Rm8k Wira & Jazz GK5 ownership experience-A long way to go
KHNG940413
668
56
528
johor bahru
Just now drive my car up to the lorry washing bay.
The way the exhaust set up is only 2 section.
B pipe & tail pipe is combine into 1 section.
Dunno what material is it.
And I shake both of my drive shaft only the driver side is making sound the other one is stable and didn't make any noise.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Wira update.
Juz bought a set of new crossmember bushing,new washer & new nut.
Wait later got free time install them. The reason I change is one of my nut gone missing agn.
From my exp, it can neither be too tight or too loose. Too loose u will lost your bolt. Too tight u will get vibration.
sifu all... what is the the pro and con of changing a lighter crank pulley on a 4G15?
i'm going to change my timing belt and water pump... just wondering shall i throw in a lighter crank pulley...
from my own experience leave it stock. A lightened crank pulley makes it rev really fast and the decelleration (engine braking and all) is drastically lighter. Really annoying mod. All the extra speed revving and slowing down with none of the benefits. It totally changes the way you drive your car and it's just not beneficial in my opinion.
And what 4G15 do you have? MMC LCPs are available but the VDO ones are super duper rare. Plus if you do get the LCP you'll need to get one with a reinforced center sleeve cuz the full alu ones will deform after a while cuz no dampening.
  • Like
Reactions: minibeany
minibeany
598
102
543
ok, thanks.... scrap the idea :-)
  • Haha
Reactions: KHNG940413
My VR one broke and replace with a solid metal one without the sleeve..... :smokin:
As you can see from the heavily shrouded example of what looks to be the latest Mitsubishi Mirage, currently being sold in the Thailand market, we were lucky to spot this test vehicle at the Saujana area that was about to be towed back to Mitsubishi HQ...
