i found this on the net long time ago. i have forgotten where i get this from. all i remember is that i did a search on "homebrew octane booster".
has anybody here done this before?
are any of these chemicals available for purchase here?
p/s: don't ask me anything. i'm not a chemical engineer.
Fuel Formulas
Please note that I would NOT suggest that a person use the following fuel mixtures without considering the detrimental effects on their engine, vital engine components (O2 sensor, etc), and other potential damage. That said, the information is interesting.
Fuel Formulas
Formula #1 - Toulene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premiums
10%...........94.2 Octanes
20%...........96.4 Octanes
30%...........98.6 Octanes
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will onlyraise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octanes
20%...........97.0 Octanes
30%...........99.5 Octanes
Notes: Similar to Toulene. 12-16 ounces will only raise octane 2-3 *points*,I.e. from 92 to 92.3. Usually mixed with Toulene and advertised as *raceformula*.
Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
R+M/2.........118
Cost...........$3.50/gal
10%...........94.6 Octanes
20%...........97.2 Octanes
30%...........99.8 Octanes
Notes: Oxygenate. Very common in octane booster products. Has lower BTUcontent than toulene or xylene, but oxygenate effect makes the gasoline burnbetter and produce more energy.
Formula #4 - Methanol or Ethanol
R+M/2.........101
Cost...........$0.60 - $1.75/gal
10%...........94.3 Octanes (Methanol)
10%...........94.7 Octanes (Ethanol)
20%...........Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasoholin 10% ratios. Both alcohols are mildly corrosive and will eat gas tanklinings, rubber and aluminum if used in excessive ratios. Main ingredient in"Gas Dryers", combine with water.
Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2.........101
Cost...........$0.60-$1.50/gal
30%...........Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
How to make your own octane booster (this is the basic formula of one of the popular octane booster products). To make eight 16 ounce bottles (128 oz = 1gal):100 oz of toulene for octane boost 25 oz of mineral spirits (cleaning agent) 3 oz of transmission fluid (lubricating agent)This product is advertised as "octane booster with cleaning agent *and*lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
Fuel Formulas
Fuel Formulas
R+M/2.........114
Formula #2 - Xylene
R+M/2.........117
R+M/2.........118
R+M/2.........101
R+M/2.........101
