R34 GTR cabin noise
JerKinXx
Is it very noisy inside the GTR?
I heard that it is very noisy.
Just want to clear up my curiosity thanks
Mine is pretty quiet except when u floor the throttle then the lovely music from the inline six fills the cabin...it's not noise...it's sexy tunes
Noise is very subjective. A Teana would be much quieter. :)
Since now discuss about noise, I wanna share my car situation. Everytime turn on the ignition, everything still ok but until I switch on air corn, rattling sound appear. And the noise will louder if my MFD show turbo is not working. All this noise will only disappear after give few time of high rev to the car.
Your turbo not working? Or you meant off boost?
Bro, my turbo work but it just "not working" on the MFD display there, mean no any response figure from MFD. Anyway, defi show the turbo is working when I giving gas on it.
Vacuum hose loose?
Are you using twin plate clutch system? If so..that the clutch that is making the sound.
mine got rattling sound...but when i step on the clutch it stops rattling...is it twin plate? because i hav never changed it before so dunno...
Oic bro, ya I'm using twin clutch now.
---------- Post added at 02:16 AM ---------- 6 hour anti-bump limit - Previous post was at 02:13 AM ----------
Mine sometimes doesn't read from a cold start too. After warming up and driving, it will read again.
Leo, u have same situation as mine. Any method to solve this? Or this is normal for all gtr?
Yes, then you are using twin plate clutch system now...may be the previous owner had changed it without informing you when he sold the car to you. Twin plate sound like a diesel engine idling and when you off the engine, the rattling noise even louder and sound like the whole car if falling apart! :biggrin:
mine got "banging" noise the moment i suddenly put in the throttle and also when i lift off the throttle suddenly, particularly in low gear and after the car warmed up.. the sound came from below (around the gearbox to the diff).. i cant explain exactly how the sound like but more or less it sounds like some loose joints banging each other..or maybe like a jerking sound. changed all the diff,gearbox oil but the sound remains..do u guys ever experienced this or maybe u guys know what's the problem??could it be a worn out bushings or something??
