I using semi racing clutch cover and clutch plate 3 puck...been using it for 1 month, and i did run in this new clutch set...
everytime when i do drag on 1st gear...(launch at 4krpm) it seems like my clutch cannot fully syncronize or hold (dunno the correct word to use) the flywheel...the clutch will "jump" causing my whole engine bay and my wheel to "jump" or "jerk"....there is no wheel spin..
when until max rev point and shift to 2nd gear...release clutch and full throttle...the same problem happen again...my whole car "jump"....is not that my engine too powerful...im just driving a car with less that 140hp...no turbo...
i suspect my flywheel surface not even or flywheel bent...but when my car is running like 40km/h on the road, i press the clutch and try to release it slowly...and there is no jerking at all...so i assumed my flywheel is ok?
anyone face this problem b4? and any solution to solve this problem?
thanks in advance...
:slug::slug:
