premix
DRFT_240sx
anyone here does it? remove your OMP in your engine and add 2 stroke engine oil
MK5 is electronically controlled right, so last time when i installed the management system, i had to convert back to MK4 version which is the manual version :P
lazy lar everytime wanna add 2t oil :P
yea berg , but it burns cleaner...
carbon is the main thing RE blow up right?
shitty goin microtech cant have the OMP... oh well...
hows your ca rnow?
You can still put 2-stroke oil in your fuel with the OMP in operation for extra measure. Stick to no more than about 300-500mL per full tank though or you might have problems starting etc etc. Been doing it for ages with good smooth running results. Now have Knightsports which already meters in extra oil with the OMP so have cut back.
i strongly think it is not ok to use the 2stroke oil with the stock OMP it will lead to a lot of problems covered in rx7club.com
what kind of 2 stroke oil to use ? .
those regular moto bike use oil ? .
can use those " 2 Stroke wangi " add in some smell ?
yes bro evinrude outboard is good but cause white smoke. I've been using it for every half can (500ml per can) with a full tank fuel. Not so sure abt the fuel/oil ratio, I just reckon. Everytime when ppl see the white smoke coming out from my exhaust they sure ask: eh, ur engine got problems ar???..hmm... would like to see the results when the day comes for my rebuild, hhaha..i.e. how clean & "shine" inside the engine... :D
but did u remove your stock OMP while doin this?
i'm rebuilding my car from the ground up and it is so tiring to gobble up so much info at once.
i think just stick up the omp to the front cover ,
block off with 10mm or 12mm bolt with brass washers ,
just removed the shaft and gears that connect to the eccentric shaft ,
