hi guys.. im building a totally new ice system.. and what i've come up with is ..
HU : Alpine CDA-9856
Specs : Includes iPod Direct Cable
50W x 4 (Max), 18W x 4 (RMS) Power Amplifier
3 Pre-Outs
Pop-up Rotary Knob
MP3 / WMA Playback
MP3 Text Information Display
Full Flap Face Design
Bass and Treble Centre Frequency Control
Remote Control Ready
Quick Search
AMp : Alpine 4ch MRV-F545
Specs : 125W x 4 RMS [4Ω @ 14.4V 0.08% THD]
125W x 1 RMS [4Ω @ 14.4V-BTL (1ch/2ch) 0.3% THD]
100W x 4 RMS [4Ω @ 12V 0.08% THD]
S/N Ratio 96dBA (IHF A Weighted Reference at Rated Power into 4Ω)
Thermal Management
500W x 1 RMS [4Ω @ 14.4V-BTL (3ch/4ch) 0.3% THD]
Comp: Alpine Type X - 177R
Specs : Peak Power: 300W
RMS Power: 75W
Frequency Response: 35Hz - 60kHz
Wood Fibre Cone and Phase Integrated Dust Cap
Custom Cast Aluminium Frame
Airflow Optimised Dual-Flare Pole Vent
1" Ring Radiator Diaphragm Tweeter with Wave Guide
Tweeter Protection Circuit
Bi-Amp / Bi-Wire Capable
3-Way/Dual Midbass Ready
Gold Plated Terminals and Connection Jumpers
Sub: Alpine SWR-1222D Type-R 12 x 1 unit
Specs : Power Handling (Peak): 1500W
Power Handling (RMS): 500W
Frequency Response: 24Hz - 500Hz
Nominal Impedance: 2Ohm+2Ohm
Sensitivity (SPL@1W/1m): 85dB
Installation Diameter: 275mm
Depth: 195mm
Kevlar Reinforced Pulp Cone
Custom Cast Aluminium Frame with Integrated Perimeter Venting and Heat Transfer Plate
Dual Voice Coil Design
HAMR Surround and Concealed Mount Gasket
Insert Push Terminals with One-sided Layout
Designed and Engineered in the USA
The question...is there anything that I need to change or add to give both..SQ and SP..but the main thing is of course SQ.. and I havent decided any RCA and speaker cable to match my system... hopefully u guys can guide me.. and I'm looking to spent about rm5~6k max and i just got quoted by one of accesories shop at SS12 for the above system..cost me about rm4.8k..is there any place that i can get it cheaper..? and of course..a good workmanship...
3 Pre-Outs
Pop-up Rotary Knob
MP3 / WMA Playback
Quick Search
Thermal Management
RMS Power: 75W
Depth: 195mm
