Main Features VSX-516-S
Output Power per Channel 100W
Impedance at Output Level 8 Ω
Number of Channels 6
Signal / Noise Ratio 88/64dB
Input Connections USB front input, 5.1 x multi-channel, 2 x coaxial, 1 x optical, 3 x audio, 3 x audio/video, 2 x composite
Output Connections 1 x audio, 1AV + 1V, 2 x composite, 1 x pre-amp for sub
Tuner Pre-set Stations 30
Remote Control SR
Power Consumption (in use / standby) 320W / 0.5W
Weight 8.9 kg
Surround Sound Formats VSX-516-S
Dolby Digital Yes
Dolby Digital EX Yes
Dolby Pro Logic IIx Yes
DTS Yes
DTS-ES Discrete 6.1 Yes
DTS-ES Matrix 6.1 Yes
DTS Neo: 6 Yes
DTS 96/24 Yes
WMA 9 Pro Yes
Surround Modes 8 + 1
Power Output VSX-516-S
Power output per channel 100W
Condition DIN, 1kHz, 1%, 6 Ohms
Rated Power Output 100W
Input (Sensitivity/Imp.): LINE 200 mV / 47 kOhm
Frequency Response: LINE 5 - 100 000 Hz, +0 / -3 dB
Signal-to-Noise Ratio: LINE (DIN) 88 / 64 dB
Power Requirements AC 220 - 240 V, 50/60 Hz
Construction VSX-516-S
Direct Construction Yes
Dimensions (W x H x D) 420 x 158 x 352,5 mm
Amplifier Specifications VSX-516-S
Large Electrolytic Capacitors Yes
Pioneer Hybrid Amplification Yes
DSP design Advanced digital core engine
Digital Signal Processor Freescale 180 MIPS 48-bit Processing
D/A Converter 192 kHZ/24-Bit
A/D Converter 96 kHz/24-Bit (2-channel)
Tuner Specifications VSX-516-S
Radio Data System (RDS) Yes
Random Preset Stations 30
Usable Sensitivity (Mono) 13,2 dBf, IHF
Sensitivity Mono at 1,3 µV / 75 Ohm 20,2 dB
Sensitivity Stereo at 1,3 µV / 75 Ohm 38,6 dBf
Signal-to-Noise Ratio Mono (DIN) 73 dB
Signal-to-Noise Ratio Stereo (DIN) 70 dB
Stereo Separation at 1 kHz 40 dB
Input & Output connections VSX-516-S
Component Video Input/Output 3/1
Composite Input/Output 3/1
Digital Audio Input 3 (assign)
Digital Optical Input/Output 1/-
Digital Coaxial Input 2
Large speaker terminals Yes
Multi-Channel Input 5.1 ch
Speaker A/B Yes, A only
S-Video Input/Output 4/2
USB Host (Front) Yes
Audio Features VSX-516-S
MCACC Yes
Midnight Listening Mode Yes
Source Direct Yes
Stream Direct Yes
Auto Surround Yes
Remote Control SR
Weight 8.9 kg
Dolby Digital Yes
DTS Yes
DTS Neo: 6 Yes
DTS 96/24 Yes
WMA 9 Pro Yes
MCACC Yes
Source Direct Yes
Stream Direct Yes
Auto Surround Yes
