sure can, what is your rim's width and offset?Eh Bro's... Perdana rear can fit 225/50/17 tyres anot ? I dun wan ketuk sidewall >.<
guys, in this matter my pv6tt only get about 400km city-highway. Is this standard FC? what is the rpm where u guys change ur gears?ya.
that FC for NA is very good.
i used to get around 450km town or 680km hiway for full tank.
i can get 720km hiway if follow speed limit..
now RVR auto gets around 350-400km town.
hiway not calculate yet.
btw, i use ron95.
to get better FC, upshift early.guys, in this matter my pv6tt only get about 400km city-highway. Is this standard FC? what is the rpm where u guys change ur gears?
err, has the problem above been rectified sir? havent heard from u since long jugek..the fuel smell only when i press hard on the accelerator. hard acceleration.
other than that, while cruising normally or normal accelearation, no smell..
not yet. i got to cuti one day then only can check. now pegi keje then balik keje sudah malam... btw, is there any way hot air can come in to the cabin from the engine bay? i can feel hot air coming in around the leg area (under dashboard)err, has the problem above been rectified sir? havent heard from u since long jugek..
yes, if there is an opening in the fire wall sir, maybe via cracked grommet kotnot yet. i got to cuti one day then only can check. now pegi keje then balik keje sudah malam... btw, is there any way hot air can come in to the cabin from the engine bay? i can feel hot air coming in around the leg area (under dashboard)
is there any way i can change the rubber grommet? do i need to take out or unplug all the wires that go thru the grommet? and i was also thinking of making some kind of cover on top of the grommet. like using big aircond hose, make it cone shaped and cover the grommet and wires.. hehe..yes, if there is an opening in the fire wall sir, maybe via cracked grommet kot
someone already recommend me to seal it with silicone, but later u wanna put some wires thru, kan susah.. tengok la, later i buy those big water-proof aircond hose and try cover the grommet..anything dat can prevent water / air leak around the grommet is recommended sir, i usually use silicone paste jer, tahan sket but a biatch to remove ler nanti
it's not like i can see it but i can feel it. it's more obvious when i switch off the aircond. i can feel the hot air coming in and blowing around my leg (and crotch) area.I hv seen hot air coming from my hood but not like what u mentioned though.
