Need some help about Modification 4g92p engine
Edisonkim
hi.. n good morning to all sifu! first all sifu here.. i would like to know that 4g92p engine is sohc engine that my big brother plan to upgrade it.. my big brother advised by a sifu dont know where is the place one la.. just know the sifu know how to mod car one.. ok the stories is this sifu recommended my big brother to upgrade this engine change the engine head to 4g93p sohc including the head onli.. well other not included manifu, extractor 4-2-1, injector 240cc, 1 more is dont know wat is that call is one the left side near the engine one.. look like a big plug.. paiseh dont know wat is that call..
total mod is quote RM2000 plus changing gasket n fix back the white smoke!
dear sifu is that ok for this mod? well this car also 1 part of me with my big brother so i ask is that good to mod klike this? thank you!
any performance gain by jz changing the cylinder head to 4g93p sohc head without changing other stuff such as throttle body and injectors??..
hi skywalker thx for reply.. inside the cylinder head was mod to bigger intake previous is 42m then final is 48m just change the whole head onli.. later after this need to upgrade extrator 4-2-1, manifu, injector and the electronic head
erm. i not sure got gain performance or not oh.. but the sifu say will better than previous 4g92p original
hi skywalker how do u think this mod? i'm not sure about mod car so much just a little know..
better change to 4G93 DOHC ( cylinder head )
nothing different if still using SOHC...u 're not change the engine block right?
or maybe yur sifu give u a high profile camshaft together with 4G93 SOHC head ?
well as i know this car been mod to highcam, mod tottle body n manifu to bigger size n setup cam n vafe and also install hks mushroom! gearbox is 1.6 mivec! this are the thing car been modified! can anyone help? just want to ask any sifu can advise me because dont want change block if change block need to register at jpj right? this car is half half de.. not fully is mine so need to change also need to get approve by my brother ma.. so sifu can help me a bit.. thank you so much!
thx for reply me SRF Racing as u mention better change to 4G93 DOHC ( cylinder head ) u mean just change the head to 4g93 dohc onli? how much is that cost oh including install? well this sifu quote me rm2000 including whole head of 4g93 sohc n tuning n change gasket!
yeap... the bore size of intake n exhaust is bigger than 4g92p.... but without changing to bigger injectors and throttle body, the performance gain is vr minimal....
try install aftermarket extractor, highflow intake filter, larger injector n throttle body, piggyback ecu and so on...
well, u are at the correct path already... jz move on and u'll able to achieve some good horsepower figure...
just use back your soch head...change tb 60mm,use metal head gasket 0.4mm,port n polish head,rebore you block to 82mm,change your camshaft & upgrade ecu also dont forget safc 5 button or new version...i can tell your hp will be around 140-150hp & tq will be 120,170-180tq....a good tuner also you must have...
i got 60mm tb,2nd metal head gasket also brand new piston....want ? pls pm me
thx for ur advise skywalker and BananaBoyz i'm very happy that can know u 2.. nice to meet u here n take ur ur help! beside this is that anything additional need to do sifu any thing else? thx for helping me appreciated sifu sifu any? thank you!
for me the best will be 1st change ur head to a DOHC head...
with a DOHC head there is more future modification to be made...
and SOHC got pretty limited modification on it...
no matter sohc or dohc, method of modification will still be the same lar...
i would agree that swapping to dohc head will gain a few more horses and will be good for further future mods...
it all depends on how thick is ur wallet.... the limits are still far from reach from the point u are standing...
well.. modification transplated head in! change to head to 1.8 sohc! just yesterday nite tested already! 0-80km not bad! 1st gear not bad 2st gear not bad but 3 gear feel like got power but cant out fast.. i press the pedal n test it feel got power but not moving fast! if not mistaken is bec of the extractor, manifu, thottle, n injector n 1 more is the electronic head! then speed is smooth but cant say power la.. light a bit when press the pedal! sifu sifu is that bec of that reason that i mention that y i feel like that? thank you reply me.. thank thank sifu! n advised
claimed back to yur sifu...
he was mod yur car not us...so we are clearly don't know what was he doing...
what he promised to u before?...is't just feel until 2nd gear only?
hi srf racing wat i mean is 1 gear quite fast up better than previous 2 gear also fast but 3 gear seem like the air cant release out got a bit delay! after that 4 gear n 5 gear smooth lo.. but havent fully test la.. i just testing the gear 1, gear 2, gear 3 up to 6800rpm around that... then enter gear 4 n 5 just enter smooth lo.. so i wonder is that the problem will be no smooth can cause because i havent upgrage manifu, thottle body, extractor 4-2-1, injector n electronic head! is that i mention just now cause of the flow air not so smooth? thank for ur reply..
seems it has been modified by yur sifu so better anything u refer back to him...
if this mod was done by yurself so it's easy to other sifus around here to assist you..
u got what i meant
hurmmm...
manifold - it doesn't actually help u in your problem...well it do IF u can do all the point length is equal...by changing tis,it cost around 1k..
throttle body - it used to allow air into the intake manifold,giving responsive to your acceleration and to set idling timing..by changing tis to a bigger TB, u might slightly feel a bit faster respond then before.
extractor 4-2-1 - i thought tis is supposed to be same as manifold ?
injector - your stock injector is ok for it..but if u wanted to go a bit more higher,is up to u...normally ppl do change injector when they upgrading turbo..
eletronic head - apa ini??distributor??or wat?
u wan smoother airflow,change to a better air filter
by telling us how fast ur speed goes at certain gear doesnt tell us any info on what modifications u had done to ur car.... so, better refer back to ur sifoo...
Thank for reply.. i just wonder my this sifu apa bikin onli.. hehe.. anyway second stage up needed.. but not so soon.. thank for the advise sifu here...
oh yah.. clanzkiller as u ask me the eletronic head - apa ini??distributor??or wat? is a distributor haha.. forget dont know is call wat ma.. so i call eletronic head in cantonese direct translate lo.. hehe paiseh anyway i think i need to change the injector first.. then manifu will let it smooth back.. the flow i suspect is the head i change was mod the intake n outake that y the flow inisde not so smooth.. compare to my previous one.. setting.. anyway i have a lot thing need to learn for u all sifu here..:adore: thank you so much!
injector n manifold well for me i won't recommand u to touch tat...even myself turbocharged,i leave it as standard yet...i only change tat during changing to a bigger turbine...well money is yours...decision is yours too...just an advise for me..don do unneccesary things when it does not actually give u wat u wan :)
