Need help regarding carcare for an Evo 7
syahrul37,
its the return pipe to the ayc pump. guess there were some particles left between the plates in the AYC pump..... the only way to get it done is to bleed it... (some once, some many times) and swapping for another AYC, but if you bleed it wrongly, then its no use changing another unit.
Moruh,
I think its ur clutch... twin plates? or hyper single?
notiguy,
thanks for ur info...i used to thought that my absorber got problem...coz the sound is underneath...but then only when braking at low speed or turning the sound appears...thank..
I've given up on the AYC problem. Serviced it twice but the annoying sound still there. S-AYC doesn't have similar problem?
7th son,
go buy those cheaper proton oil and bleed it thoroughly... turn left, right while bleeding it... try braking too. :) it should go... but then again, mines still around... couldnt be bothered by it... hope to swap for a S-AYC...
Z
Replies
Views
1K
][zoohalee][vtec][
Z
Z
Replies
14
Views
3K
][zoohalee][vtec][
Z
