my engine kabbooommmm
tom's said:
not too sure but i plan to use ultrasonic to clean my injector before i put the eng in back.......then only i'll know
sorry to be keh gau, but i think on top of cleaning up the injectors, should also test to see if it's performing properly before putting it all back to the engine...oh, and the injector wiring as well, just in case. :)
the problem i found out is the valve hit the piston until pecah....the other 3 piston shows some chips kena by the valve
Any update?
Alvin,
Any update on you engine.
Already found out what happened to your engine?
The valve hit the piston?
chu......that should be the main aspect...... coz so ngam the 2nd piston ex valve no clearance.....it might move more than the other
car now also belum ready....should be next month.....next week busy with super gt liao
