Microtech
i have some question.. how do you know what sets of system you need to install in your car?
thinking of installing soem basic standalone system to replace my currently problematic ecu system.. what might be the cheapest solutions?
simple....
basic....
LT10s perfect for 4cylinder full sequential function.....
LT12s perfect for 6cylinder and 8cylinder
LT16s best for either 6,8,10,12,16cylinders........
so if u are using at 4cyl best opt for lt10s....
perfect enuff for up too 60psi of boost... hehehe :)
merry christmas n happy new year :)
Bro,
Still awaiting for the wiring diagram for 4G93T.
Especially required for the home and trigger part before I start my Sprint 500 project.
Also, if posibble the basic setup information such as trigger e.t.c and also base map.
Thanks a million bro.
Rgds,
Raymond
Email to: [email protected]
Bro,
Rgds,
Raymond
hey settle d ar?
ekkekeke :p
60psi and 100psi map sensor option NOW available..
not yet bro... just emailed haltech and they told me how to wire it up edi.
awaiting the vehicle to run-in first b4 install... next month b4 CNY la hopefully.
Still thinking how to set the angle and tooth thingy la.. deng.
bro jo, when you coming over to penang ?
...maybe next week or week after next...
---------- Post added at 01:26 AM ---------- 6 hour anti-bump limit - Previous post was at 01:24 AM ----------
ok bro glad u got all organised :)
good then bro, hope to see you soon, wanna tune my car again with its fresh engine..currently running in now...
joshua,
thanks man for the ECUs.. hehehe.. the MIVEC CK with LT10s is all up and running edi...
hi there bro josh..can u quote me the price of LT4 plus installation n tuning for 4g92 sohc. i juz need to control the fuel. coz i want to get rid of the airflow sensor. LT4 can remove the airflow sensor right? and does it also come with a map sensor? coz i dont think 4g92 sohc wiring has a map sensor..thanx bro and looking forward for a reply hehe:itsme:
hi, mr. joshua. i would like to ask some questions about microtech LT10, i m using microtech LT10 that is running with VDO system on my 4G63 engine. actually before this, the microtech LT10 is used in Satria GTI 4g93 engine. This system is using 2 sensors, CAM sensor and CRANK sensor. Is that ok if i don't want to use CAM sensor in my system? because I tried to pull out the CAM sensor, my car still can running smoothly. An early reply from u is very much appreciated.
when you are running only crank position sensor the ECU will not know if you are in exhaust or intake stroke. no problems if you are running injector batch firing. but perhaps you will encounter problems when running full sequential firing. I'm not too sure about this... Joshua knows better.
but VDO system in a 4G63? hmmmm.... when you change to LT10s there is no need for the VDO.
original MR-S.... wan to install MT4 / LT4 to control fuel only...
Good or not.. ? Big different ?
hello josh
good day to you.. is the promotion for LT10s still on? wanna install in on my Mivec CK..
also wanna discuss about the mapping with you... prefer to have 2 separate mapping for daily drive and for Drag purpose... well, out of 30 days in a month, only 1 day we bring our beloved car to participate drag event, the rest 29 days is for daily drive.. hehehehe.. can i text you for appointment? currently, car is under running condition, just came out from workshop.. tqvm
== L€T10s plus instalation and dyno tuning would cost you RM4500
Is the LT10 RM 4,500 complete with the
== Handset 4line
== dash unit
== laptop adaptors
hello josh
Microtech can't do 2 mapping switch.Only one time tuning.U can save 4 map from your hand set.
