Max Booster
loong1
Elf Max Booster
2-in-1 octane booster and fuel injector cleaner!• Restores engine's power performance.• Maintains cleanliness of fuel system and protects against corrosion and rust formation.• Cleans deposits on fuel injector for better and more efficient combustion.• Reduces pollutant emission to the environment.• One measure treats up to 150 litres of petrol or use once a month for normal usage.• 250ml.
Elf Octane Booster
So you want to go faster? Try Elf Octane Booster. It will put European grade fuel in your fine European car. Get more power while you can, until quantities last. Octane booster increases horse power and acceleration, reduces engine knock, improves combustion and reduces heat build-up.
The Elf Octane Booster enhance the fuel's octane rating. This translates into more efficient burning of the fuel and potentially improved fuel efficiency. It also contains specific upper cylinder lubricants that ensure easier piston travel and valve seat protection. It also ensures maximum life and performance from pumps, and injectors. It eliminates spark knocks, pinging and dieseling while promoting clean fuel burn for fewer emissions and more horse power.
A genuine performance enhancer suitable for use in engines.
