Not all LCPs are undersized. I personally don't recommend undersized either unless your car's a race car and is always high revving the crap outta the engine.
I'm using the which is slightly (3% to 5%) undersized... and the difference is the acceleration. That's it. Top speed, torque, HP, all not affected.
However there's a risk when using LCP, the rubber dampener on stock CP is called a "harmonic dampener". It absorbs minor or any sort of vibration caused by imbalanced crank or generally the whole assembly. Without the rubber you run the risk of wearing out your crank oil seal or the crank pulley much faster. No catastrophic damage or whatever scary stuff.
My crank assembly and my original pully was balanced when the engine was rebuilt. When it spoilt (the pulley) I changed to 2 original pulleys and each one got damaged one way or another. Imbalanced pulley la, damn loud squeeling noise la, then finally I swapped to the LCP. Now I change my crank oil seal about every 5 to 6 months because of leaking problems.
So not only do I have to worry about harmonic vibration, I have a problem with balancing too but at least the CP is no longer breaking down like the earlier 3 OEM ones.
