KZT Racing/Drifting full adjustable shock absorber for AE86 n KE70
dorifmon
NEW...!!!! KZT Racing/Drifting full adjustable shock absorber for AE86 n KE70
28 step of hard/soft adjustable,spring high/low adjustable,full shock body adjustable-this fully adjustable shock absorber suit each car n driver's needs.height adjustment becomes crucialin racing n drifting when setting up corner weight or difference front /rear height.
spec :
-28 step hard/soft adjustable
-front n back high adjusted
-spring height adjustable
-shock body height adjustable
-spring rate hard/soft setting available from 4kg~18kg
-monotube hydraulic design (like tein mono flex)
-large 54mm diameter intensified alloy (alloy shock body)
-single tube gas hydraulic design
-coil spring utilize SAE9254 steel
--Special corrosion resistant coating on the threaded shock body.
Fully threaded for maximum adjustability.
-Strong and lightweight anodized aluminum spring perches and lock nuts.
-Height Adjustment
A comprehensive range of height adjustment available without affecting the spring pre-load or damper stroke length.
-Reinforced Steel Lower Brackets
The strongest steel lower brackets with anti corrosion coating and integrated brake pipe fittings specifically for your car.
-Toyota AE86/KE70 units are built using your OEM lower spindles with all new strut bodies
serious buyer,please contact : 012 278 7115 (DONT SMS) for price n more information
**we do accept custome order for those car model cant get their performance shock absober in market,like ford escord,Datsun 120Y,BMW E30,etc....
brand - Axis
model - OG oldschool
brand from USA - Axis Wheels - The Result of a Passion for Automotive Excellence
size - 15x7+10
PCD - 114.3 x 4holes
WEIGHT - 6.62 kg
this rim is USA brand but dont think is made in USA coz the price is cheap.
[URL
[/URL]
or
http://img139.imagevenue.com/img.php?image=24677_og_oldskool_blk_lg_enlarge_122_171lo.jpg
interested plz contacat 012 278 7115 (dont sms),serious buyer plz call for best price....
i very seldom online.....so its not good to PM me... so best way to get more infor about this rim is jz call 012 278 7115 (dont sms)
-trade in welcome
-credit card welcome
-we can send this item to your
-dealer welcome
new stock arrive....!!!!
NEW !!! NR-G(USA) 10.2mm triple core power plug cable for proton/mitsubishi 4G93 (NA) engine...
available for more others engine n models.....like 4AG,4G92 Mivec,SR20,etc....
-credit card accepted
-sending service provided
-dealer welcome
call 012 278 7115 for more infor (plz dont sms)
thx
