Guys & Gers...
I wanted to let go of my precious player Kenwood KVT-735DVD. All in good conditions. Complete set with manual book, remote, player box compartment and wire harness.
Price at: RM3500.00 (used for 1 year)
Call me at 012-3856067 if you're interested. Warranty given by owner for 2 months.
Specs as below:
Features Highlights
* 7.0 inch Wide Colour TFT Active Matrix Display
* New Full-automatic Open/Close Mechanism
* IInteractive Touch Panel Control with GUI
* Audio Easy Control Mode while Playing Visual Source
* MP3/WMA Folder/File Search Function on OSD
* Secondary Display = 5 x 7 Dot Matrix LCD (Colour: Green, Red & Blue)
* Selectable Key Illumination (Green/Red)
* Amp Control System with '04 eXcelon Amplifiers
* Maximum Output Power : 50W x 4 (MOSFET Power IC)
* 3 Preouts with 5V Pre-output Level
* 1 RCA AV Inputs/ 1 RCA AV Output
* System Q/ System E's+
* Dual Zone Source & Volume Control
* DVD±R/DVD±RW Compatible (Video Format Only)
* Dual Disc Changer Control Capability (with Optional KCA-S210A)
* Optional TV Tuner (KTC-V500N/P)
General Features
* New Full-automatic Open/Close Mechanism with More Installation Possibility
* Motorized Tilt Angle Adjust (8 Step)
* Motorized Back and Forth Display Position Adjust (4 Position)
* Interactive Touch Panel Control with New Smooth GUI
* Multifunction Key Operation
* Number of Pixel: 336,960 pixels
* Screen Size: W154.1mm X H87.0mm
* External Hard-key Operation (When Monitor Closed)
* Amp Control System with '04 eXcelon Amplifiers (Max. 8 Amps Controllable)
- Parametric EQ & Gain Control from Head Unit
- Amp Information Display on Head Unit(Voltage/Current/Temperature/Fan Speed)
- 2nd Generation B.M.S.(Bass Management System) with '02 eXcelon Amplifiers
* Digital Clock (24H)
* DAB Ready with Optional Unit (KTC-9090DAB)
* Supplied with Remote Control Unit (Card Type)
* 2-way Telephone Mute
Single CD Features
* DVD Video Player
* VCD Player (Audio Output St/L/R Selectable, Play Back Control Supported)
* WMA (Windows Media Audio) Decoder
* MP3 Decoder with ID-3 Tag Display
* Multi-session Disc Playback
* CD Text Ready
* CD-R/CD-RW Compatible
* Random/Repeat/Scan Play
* Direct Access with Remote
Changer Control Features
* DNPS (Disc Name Presets) with Compatible CD Changers
* CD Text Ready with Compatible CD Changers
* Random/Repeat/Scan Play (Disc/Track)
Tuner Features
* FM(RDS)/MW/LW 24 Station Presets (18FM, 6MW & LW) with Radio Text *KVT-725 & 735DVD Only
* FM/AM 24 Station Presets (18FM, 6AM) *KVT-745 & 765DVD Only
* AME (Automatic Memory Entry)
* Up/Down Seek Tuning
Audio Features
* 1 RCA AV Output (PAL or NTSC according to the source)
* 1 RCA AV Input (PAL/NTSC Automatic Selection)
* Video Input Signal Automatic Detection Mode (Normal/ AUTO)
* System Q:Sound Control with Pre-programmed Tone Curves
* System E's+ (Built-in HPF & LPF)
* DRC (Dynamic Range Control : Wide/ Normal/ Midnight)
* Attenuator(-20dB) with Smooth Volume Return
Optional Unit
* TV Tuner (KTC-V500P/N)
* 10 Disc DVD/VCD/MP3/CD Changer (KDV-C820/830/840/860)
* 10 Disc MP3/CD Changer (KDC-CPS89MP)
* 10 Disc VCD/MP3/WMA/CD Changer (KDC-CMP21V)
* 10/ 6 Disc CD Changer (KDC-C719/ KDC-C669)
* DAB Tuner (KTC-9090DAB)
