KENWOOD DESIGN J-7683G 7" Double Din Motorized VGA Monitor DVD/B.T/USB/SD/IPOD/TV/GPS
ICE -In Car Entertainment
shaharel
* Retail Price: Rm3388
* Promotion: Rm2388 only!!!:driver:
* Power supply: DC12V
* Power range: 10.8 ~ 16.0V DC
* Max operate current: 10A
* Ground system: Negative ground
FM tuner
* Frequency range: 87.5 ~ 107.9 MHz
* Signal / noise ratio: 55dB
* Stereo separation: 30dB
* Search station volt: 20 ~ 30dBuv
* Distortion rate: <1.5%
AM tuner
* Frequency range: 530 – 1710KHz
* Limit noise sensitivity: 32dB
DVD player
* Signal/ noise ratio: 70dB
* Frequency response: 20Hz – 20KHz
* 7” motorized TFT LCD display
* Compatible with DVD/ DVD-R/ VCD/ MP3/ MP4 (DIVX)/ CD/ CD-R/ CD-RW
* Touch screen - USB port in front panel
* SD card slot - Ipod ready
* Bluetooth function with built-in MIC
* FM/AM radio, 30 preset station
* Rearview CCD video input
* Built-in TV tuner, 100 preset stations
* Built -in GPS navigation system with latest Malaysia IGO Map
* If you want to download other country map or the latest Malaysia Map, you can go to this website: http://www.leoidea.com/tag/igo-maps/
* Product Weight: 4Kg
Why should you buy??:
1. You can't find a similar product same as this model. We are the main importer for this product from Taiwan, the same manufacturer with KENWOOD & JVC
2. This product is not KENWOOD, the design is similar like KENWOOD DDX8034BT, but this product have more function then KENWOOD DDX8034BT, it have In-Built GPS but KENWOOD do not have GPS.
3. GPS Mapping & Signal - This product have the latest update IGO Malaysia Map, we are using the best stage 3 GPS Antenna for this Double Din, even you go under tuner or bridge also can use. The GPS will only need 3 Second to connect to the statelite. I can say this is the strongest GPS receiver in the market. If you want to download world Map like Singapore, Thailand and etc for FREE, just go to this website and download, then you paste the file inside your SD Card under MAP folder: http://www.leoidea.com/tag/igo-maps/
4. Monitor Quality - This is not LCD or TFT Monitor, this is using VGA monitor, the same monitor like SONY, KENWOOD, PIONEER, JVC, PANASONIC Double Din, the quality and refresh rate of the Monitor is very high, you can see the picture very clear even during morning or afternoon drive.
5. High Quality Motorized Monitor - Alot of china double din will come across sensitive motorized monitor, this double din have been embedded with heavy duty motor for the motorized monitor.
6. USB 2.0 - This double din is running on USB 2.0, it can scan Songs & Movie really fast from your tumb drive or even hardisk. The USB port can also use to charge your hand phone
7. SD HD - This is not a normal SD Card Reader, it comes with HD technology, means it can read unlimited storage spare in your SD Card, normally china double din only can read up to 4GB, but this can read up to 32Gb and even more, same as the USB drive.
8. BLUETOOTH 2 - The double din is running on Bluetooth 2 technology known as Bluetooth Stereo, not only you can connect your phone to make phone call, you can also use your phone to play music and it will output it on the car speaker. The best bluetooth technolgy I can say.
9. DVD/CD Input - Malaysia china double din come across their DVD or VCD or CD stuck inside the player and can't come out, or when the car jerk or go over a bump, the music will jump, this double din comes with anti shock technology and it won't get your DVD stuck inside the player
10. High Accuracy Touch Screen - The player comes with High Accuracy Touch Screen Panel, you can use a stylus to test the accuracy of the touch screen, it is 99.9% accurate.
11. High Radio & TV Reception - It have High Quality TV & Radio booster in-built, match it with a good TV antenna and you get really clear picture motion, even if you drive your car, the TV quality is still very stable
12. Multi Format - It can support alot of type of Format such as DIVX, RMVB, MPEG, AVI, JPEG, PNG, WMA & etc, because it have in-built codec supported by Microsoft
13. IPOD Ready - If you have IPOD, you can connect it to your IPOD, you can use the IPOD adapter to charge your IPOD
14. Multi Tasking - You can multi task in the double din, means you can use your GPS and also listen to the radio or your DVD or your IPOD, it is very flexible.
PM me for best price or contact 012-3396568
Re: KENWOOD DESIGN J-7683G 7" Double Din Motorized VGA Monitor DVD/B.T/USB/SD/IPOD/TV
Best offer!!!! PLS CALL
bumping!!!!!!!!!
bumping
bump!
bump!
bump!
bump!
