10 years back a lot ke20/30 has been using Levin LSD was seen in KK,so I think it would be direct fit.Some more that time only selling rm300.00....how nice if still can get that price!!
S13 using IRS,too wide &very difficult to fix.
need help from all master
as topic,
persona B line (M)
start engine RPM run to 8k can drive but agar 3k rpm then cut off.
use OD check error code water temperature sensor voltage low.
i change the sensor, few hours...
I noticed and heard some sounds out from my sterring whenever I trying to turn to left and right (sounds like a spring get loose like that) :confused_smile:
Do you know what is the problem? I had check the...
