Kancil tuning
since tis is kancil tuning...
i wanna otai2 here...
normally what tire u use?
cos i'm thinking of changing rims
but pcd 110 n 13" rare leh...
i found 14" titan racing-emotion alike...
but tire should be 150X55 right...
i based on the article on hypertune...
but hard to get leh
Haha, tyres ar? mine still with stock rims, but front tyres are newer than rear ones, coz front wear faster, so front is Goodyear, rear is Bridgestone. Damn funny. I don't know much about tyres' measurement, can't help you. However, according to bro Equinox, he's using slick tyres which are available for 14" rims and above only, and I heard that slick tyres are great.
i heard slick tyres give alot of stain to ur suspension.is it true? im not that imformative in the tyre business.:_:
for 14", the tyre available sized at 165/55/14 this is for the 5JJ or 6JJ wheel. Yokohama AD07 and Toyo Trampio got this size of tyre. but of coz there are other brand like Bridgestone Potenza or Falken Ziex
i'm using Silverstone FTZ Type RR semi slick sized at 185/55/14 for daily application. My another set of slick is for competition only, sized at 185/525/14. FYI, slick tyres is not used for daily driven. it's not threaded and its dangerous to drive in wet condition, otherwise the traction is good - but u wouldnt wanna pay so much for such good grade rubber to be use on road.
don understand your question what are u trying to find out? Slick tyre once warm up will give very good grip but its should not kena water or sand stuff and its not meant for daily ride.:regular_smile:
okie...boss got wat u mean...
will scout around n see
i guess wat fluffy means tat the slicks will burn off n deposit on the inner wall n suspension...my guess
bro equinox...thanks for the info...
but not into slicks...jus want normal drive tires
DC! said:
hehe, bro.. caught! got a typo there..
DC!.
it's not a typo. if u noticed, all the competition tyres got some unusual aspect ratio (most of them).. so my yokohama slick is sized at 185/525/14 - 185mm width, 52.5% of aspect ratio and for 14". kinda low profile for a 185 series tyre..
for normal use, try those mid end one available from Falken or Bridgestone.. for something good for ur 14", try AD07 or Trampio.
but somehow i heard Toyo discontinued all the Trampio series of tyres.. been replaced with Proxes series.. so i dont know of Proxes got the size for our 14" anot
So, if you suggest Falken and Bridgestone, then you mean they are better? There's been alot of sayings that which brand is better than another, I am curious too.
Wah...nice forum to join..
bro.. how much the price of toyo/yokohama? planning to replace new 13" tyre but dunno which 1 is better..thinking of gdyear..
lattest price that i notice; goodyear 13" RM120, toyo trampio 14" RM180 - JB. KLANG dunno the price. and yokohama also dunno..
stock_kancil said:
hei munpeng, how your budget? i give my experinced to u how my mod on 850 auto NA
1st level
3 - 1 extractor from zenden - only RM180
zenden bullet - RM80
some simple piping mod - RM40
TOTAL - RM300
2nd level
mod on carb, valve resetting, - RM315
cam shaft resetting
coil upgrade, use plug perodua kembara (NGK-R)
* standard plug cable & standard filter box
3rd level (future)
full mod on exhaust system; = -+ RM600
1.8" piping custom design, bullet,
mufler & mufler tip.
* dont use straight flow design since that one is for turbo. NA use S flow.
stock_kancil..i'm interested with the korek cab one la...where i can get the service...
tq
if NA using straight flow what are the effect? flow according to the piping shape rite? spark plug cable what are the benefit if more mm? still new in engine mod la. hehe. sifu can answer?
toyo trampio got 165/60/13...but looks like discontinue edy....price is RM190 last time i asked..lolz.....
straight flow for what engine setup?? and i think whats important is the plug cable cores, how many cores?remember...if the exhaust piping too big, u will lose top-end..too small will loose low-end,..its kinda hard to get correct piping diameter for a specific engine setup but experience tells
for the exhaust its rather simple, do the microphone effect. smaller diameter piping for the front part and bigger diameter for the back part.
bro equinox,
what do u really mean?let say on stock L200..how many inch the diameters need for the front and back with the catalyzer still?
if dun use muffler? centre bullet straight pipe? NA engine la bro. manual. manual n auto diff kind of shape flow? cores is the tebal of the cable rite?
Write your reply...
